Allright... heres what ive got in the box... 120mm intake fan in front 90mm intake fan on side 2x 80mm exhaust in back 90mm exhaust on top Tt Volcano 6 CU+ CPU Heat sink/fan Chipset fan Fan inside PSU With all of these fans, my tower sounds like a friggin airplane, and my temps are as follows: Case 1: 21C Case 2: 25C CPU: 35C For all the noise i go through, these are not the temps i was lookin for... why in the world would the temps be so high??? AHHH 35 isnt a bad temp for the CPU, but 25C case temp is outragious for the amount of fans ive got in this beast... maybe a problem w/ fan placement??? i dont know... someone willing to help me out???
25 is just over standard lab temp... (76F.... 23C) unless your room is lower than 23C you won't get much lower than that considering you're taking in air thats already 23ishC and putting it into a warm environment
