Cooling Cooling Options
Discussion in 'Hardware' started by Morphious, 13 Sep 2004.
  1. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    What options, besides standard fans, do I have for cooling my case? It is fairly small and cramped, but I might look at getting an external resivoir and pump.
    What other cooling options could I pursue on a somewhat limited budget?
  2. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    resinator kit will cost u a straight hundred and thats that.
  3. Risky
    Risky Modder
    10 Sep 2001
    :confused: :confused: :confused: http://www.google.co.uk/search?hl=en&ie=UTF-8&q=resinator+kit+&btnG=Google+Search&meta=
    IF you have a very small case you can get a watercoling kit with the pump and radiator external. E.g. the Reservator Kit
    http://www.overclock.co.uk/customer/product.php?productid=17494&cat=566
    for £150+VAT
    However you can normally fit an internal kit with a bit of work unless your case is really minature and/or packed with kit. Give us some more details and we might get you some better advice.
  4. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    depends on the budget
    koolance exos
    corsair hydrocool
    zalman reserator (fully fanless, looks great.. and good performance)
    vapochill/mach phase change cooling.. the best money (alot) can buy
