Cooling problem
Discussion in 'Hardware' started by soul_assassin, 18 Jun 2002.
  1. soul_assassin
    soul_assassin What's a Dremel?
    18 Jun 2002
    I am having a problem with cpu temp.. it reaches 47/48 degress whilst using less than 10% of the CPU..... any ideas??
    my current system is:
    Cheiftec full tower case,
    K7N420 (nForce) mobo,
    Athlon XP1700+ w/ Dragon 3 HSF,
    512mb ram, ...etc...
    3 80mm tt fans in the front,
    1 80mm on the side,
    2 80mm in the back & a 120mm panaflow fan above the CPU...
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    check to see if heatsink is seated properly or thermel compound applied.
  3. soul_assassin
    18 Jun 2002
    It is definitely seated properly & has a thermal compound applied... although it is the standard themal compound which came with the HSF
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    use AS3...that shuold help....also unless your system restarts those temps should be fine....wat brand mobo is that?? sorry dont know the nForce boards...:sigh:
  5. soul_assassin
    18 Jun 2002
    mobo make - MSI (Microstar)
    ... when i try & run Genome@home (uses un-used cpu to crunch out genomes - like Seti@home) it lasts 30sec to 5mins before the temp exceeds 53 degrees
  6. felix the cat
    11 Jan 2002
    does it crash your pc??
  7. soul_assassin
    18 Jun 2002
    nope... (well hasn't yet) just emmits a loud alarm sound from the internal speaker.... indicating the temp is too high... i shut down all running apps... etc... if the sound keeps going i shut it down... leave for 5 mins.... then turn back on
  8. felix the cat
    11 Jan 2002
    hmm...people do really well cooling wise with that case, and you have loads of fans in there so i dont see why you get such high temps...
    wat are the case temps...
    on thing so the dragon orb is an awful heatsink...so performance wise it aint to great...
  9. soul_assassin
    18 Jun 2002
    case temp has now dropped to 28degrees during the day was 32 degrees...
  10. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Check the airflow through your case. You should have intake fans at the front and an exhaust at the rear! And besides, with a dragon Orb you can't really expect too muc. They may look Ok but they aren't up to much cooling wise! Oh, and as Flix said, get some decent thermal compound!
  11. felix the cat
    11 Jan 2002
    id also replace the tt fans while youre there...
