Cooling the SB Audigy
Discussion in 'Hardware' started by Telkman, 14 May 2002.
  1. Telkman
    Telkman What's a Dremel?
    22 Apr 2002
    Is it worthwhile cooling the processing chip on a SB Audigy?
    If so, would a thermaltake crystal orb do the trick?
    how easy would it be to fit? and would i need anything else to keep it on there?
    Thanx (look at the side - i'm a n00b)
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    why would you want to cool your sound card. its not like you are going to overclock it.
  3. Telkman
    22 Apr 2002
    yeh, but when ur doing any demanding stuff with the sound, it runs very hot, and then performance degrades.
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    you are talking a minute performance decrease and a minute temperature decrease....unless of cours this has somethin to do with the firewire which i dont know about...
    but seriously...what do you use to hear that difference in performance decrease??
  5. Telkman
    22 Apr 2002
    like i said in #bit, i've not got one yet, but going by the opinions of others and giving my m8s a prod, its certainly hot. ur prolly right.
  6. felix the cat
    11 Jan 2002
    didnt wanna spoil your moddin fun though....
  7. Will
    Will Beware the judderman...
    16 Jun 2001
    If cooling it is your thing then fine, but dont use any Orb or anything with a fan. The noise of the fan will be far more noticeable than the slight change (as in pretty much unnoticeable)in sound quality as the card heats up.......
    IMHO a heatsink alone would do the trick fine! :)
  8. Lazy
    Lazy Meow?
    13 Nov 2001
    i don't think that haveing the card running cooler would give you a better quality of sound.
  9. Telkman
    22 Apr 2002
    i think ur prolly right. just hs should do. ta for help gents
