Cooling cooling the vapochill
Discussion in 'Hardware' started by Boswell, 13 Oct 2005.
  1. Boswell
    Boswell Minimodder
    23 May 2005
    ok i am thinking of buying the Vapochill Lightspeed AC in Black
    here is the link of it if that doesn't work go to here then--> vapochil at the top --> Vapochill Units --> then 3rd from bottom. But i have a friend who has this but says it is quite loud... now this can't do :grr: wondering if anyone has this and couold find out for me whether its the noise of cooling the vapochill or the actual noise of it creating the coldness. I think its both in which case does anyone think it could be possible to cool the vapochill by a big rad i have (aqua computer 1800). Would be a nice thing :) thanks
    B.
  2. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    The compresser usaly makes a slight hum, but its the intake fan that makes makes most of the noise, but in the Lightspeed they usaly have to be near 70%+ of there full speed to work affectivly, there for the noise :sigh: , somepeople on procooling tryed to watercool the condenser rather than use a fan and it dint go to well :(
  3. Boswell
    Boswell Minimodder
    23 May 2005
    ok thanks for info, few things stopping me from buying it.. it wouldn't fit under my desk (while attached to my computer) and also my computer would then be nearly impossible to lift (to go to lans) and yes i go to lans often enough (hosted by moi :p ) to worry about this and lastly the obivous one .. money
    B.
  4. sc4mpi
    16 Jan 2005
    good move stick with water :thumb: more fun
  5. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    Water all the way unles you are an avid OC'er or like to win COMPETITIONS at large coovnetions such as quakecon and you could win an entire ALIENWARE setup.!.!.!
  6. fatty
    fatty Minimodder
    12 Jul 2004
    I fitted my mach2 gt into a lian li v2000 so its got wheels :)
