Cooling Coollaboratory Liquid MetalPad
Discussion in 'Hardware' started by Nexus27, 1 Jun 2012.
  1. Nexus27
    Nexus27 New Member
    30 May 2012
    Has anyone had personal experience of using these pads?
    Are they easy (ish) to remove? How well did they work.
    I'm considering using them on an i5 Ivy Bridge with the HeatSink removed and an Antec 920 water cooler.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You mean without the IHS?
    It could work, but you'd never get the CPU off the waterblock without breaking it...
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Or superheated cheese wire...
    But yeah, that's the issue. It more or less fuses the CPU IHS to the heatsink, usually, applying it to a raw die would glue it straight to the heatsink, which would mean you'd either have to get down there with an absolutely microscopically thin razor blade, or you'd have to try and work it off the die while still hot.
    On the cooling front; those things are outright amazing. They provide some of the best temps out there, but the issue is the startup; When you're using them; YOu'll get scarily high temps as it melts and changes into the solder-like compound, so it can only work on Intel processors. Secondly; You can never truly remove it from either the processor or the heatsink without Lapping it, which removes the processor ID codes from the top, because they're just etched into the metal, and you've just rubbed some of that metal off.
  4. feathers
    feathers Well-Known Member
    11 Apr 2009
    I was considering it a week ago but I don't want CPU welded to waterblock. Can't remove cpu unless the stuff is heated and using razor blade not an option for me. I'd rather buy an aquarium chiller to get truly low temps than feck my cpu, mobo and waterblock.
  5. .//TuNdRa
    12 Feb 2011
    And this is why AMD's ancient socket design has an advantage; if the damn processor will not let go of the heatsink because the thermal compound has sealed it; a sharp enough tug will remove the processor too. Doesn't even bend the pins if you pull straight up!
  6. feathers
    11 Apr 2009
    I wooden wanna go back to pin matrix processors.
    Used to have bent pins on my P4 because it was being unplugged so often for refitting of peltier/waterblock. Used to have to straighten the pins under magnifying glass. Feck that.
  7. .//TuNdRa
    12 Feb 2011
    How rough are you with your processors? my FX8120 has laughed at everything i've thrown at it.
    Heck, even my old Athlon64 (Dead, before anyone freaks) was sat pin-down on the floor for three months. Only the right edge of pins were bent from where I'd dropped it previous, the rest were fine.
  8. b1g-d0g
    b1g-d0g Well-Known Member
    30 Sep 2001
    Dont use it mate very bad to get off guy on ocuk had a bad time with it.
  9. .//TuNdRa
    12 Feb 2011
    As I've said before; For a machine that's going to be running for a very long time; It's outright amazing. It'll last almost forever and it transfers heat exceptionally well; It's just a transformational compound, it melts, then FUSES the two surfaces together. This provides a massive amount of thermal throughput, it's just the issue is it's basically low-temperature soldered the heat-sink to the CPU. Hence the issues in getting it off.
    Tl;DR; If you're never going to take your PC apart again, or not going to do so for at least five years; this stuff is awesome.
    Otherwise; It'll annoy the hell out of you because it's such a swine to remove. (So put this shiz in Servers. That should increase the lifespan of those chips by one hell of a bit.)
  10. Itchy Rim
    Itchy Rim Member
    3 Jan 2012
    Useless they are, I tried one on a CPU and it never bonded, my temperatures were 5C above normal and when I took the waterblock off the pad was still sitting there without bonding.
    I have a couple of these going spare if any toby wants them for nowt, you will have to collect as I cannot be bothered using a stamp and going to the post office, that's how useless they are.
    Itchy Rim
  11. .//TuNdRa
    12 Feb 2011
    Depends on the CPU. I hear you need to hit at least 85 degrees through the pad itself to get it to bond. So it may take some extreme overclocking just to get the thing to behave. All I know is; AMD can't do it. It just can't.
  12. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Sounds like it would work great on a new 680 W/Water block
  13. Itchy Rim
    Itchy Rim Member
    3 Jan 2012
    I bitched mine up to at least 82C to 83C for a few hours and it never bonded, mebbees I should have bitched it higher?
    Itchy Rim
  14. .//TuNdRa
    12 Feb 2011
    Perhaps that pad was faulty? I'm not the expert on these things, I only report what others have told me. That or they've got scarily high melting points, which I wouldn't advise anyway.
  15. feathers
    11 Apr 2009
    I thought the melting point was in the 90's? And it doesn't require hours does it? So long as you reach correct temp it happens pretty quickly as far as I know.
  16. Itchy Rim
    Itchy Rim Member
    3 Jan 2012
    Well, I got two spare as freebies, plus the brillo pad and solvent sachet they give you to remove it from the HSF/CPU if any toby fancies giving it a go.
    They come with a wealth warning - this crap can seriously damage your wallet, past performance is no indicator of future results.
    Itchy Rim
  17. feathers
    11 Apr 2009
    I refuse to do it and you won't make me.
  18. Jackypoos
    Jackypoos Will it blend?
    6 Jan 2008
    Just for clarification, melting point is 58C.
    I'm interested in these, Coollaboratory always does the awesome but risky stuff ^^
  19. .//TuNdRa
    12 Feb 2011
    ... I call bullcrap on that, otherwise it'd be compatible with AMD processors. And it sure as hell isn't.
  20. Jackypoos
    6 Jan 2008
    @Itchy - I might be interested, though I could just pick some up from Scan. Anything in particular you want tested?
    Bah, maybe your temp monitor is being too generous with the numbers? ^^
    I found a datasheet on tom's hardware if anyone's interested.
