Modding copper, brass etc
Discussion in 'Modding' started by pranks7er, 23 Sep 2003.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    There are so many home made HTPC alu cases out there has anyone ever made one out of copper or even brass?
    i was just looking at this site http://www.metalsontheweb.co.uk/asp/home.asp and i wonder if anyone has made cases out of these metals?
  2. Shogun
    Shogun Banned
    18 Jul 2002
    i remember visiting a site once where a person had made 3-4pcs out of copper tubing. dont think they were htpc's tho.....
  3. Paperbag
    Paperbag What's a Dremel?
    28 Jul 2003
    Wouldn't a case made of copper or brass be rather heavy? Depends on the kind of case, of course. But still.
    It could end up looking quite good though, if you gave it a nice polish.
  4. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    also, very expensive, but if it was made out of copper and given loads of really fine fins down the side, the case could work as the world's best heatsink-- you could use a heatpipe from the processor HS to the case to conduct the heat away... :D
  5. ModCanada
    ModCanada What's a Dremel?
    24 Sep 2003
  6. pranks7er
    25 Dec 2002
    that would be "cool" really!
  7. pranks7er
    25 Dec 2002
    mmm may build a copper one someday
