Cooling Copper or Alu ?
Discussion in 'Hardware' started by sinizterguy, 21 Jul 2003.
  1. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Which material is better for making waterblocks ?
    Copper or Aluminium ?
    I plan to get some waterblocks made some time in the near future. So which material is better ?
  2. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Copper
    Its got a better heat conducting properties then aluminum so go for it
  3. Guest-16
    Guest-16 Guest
    copper has a larger specific heat capacity per gram too - and so does water compared to air so they are better matched :)
  4. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    neither, carbon in its diamond form is far superior, and non electrically conductive
  5. Supercool
    Supercool Gone.
    31 May 2003
    Re: Re: Copper or Alu ?
    you buy me a bar and I'll make a waterblock out of it :)
  6. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    You can machine copper thinner than aluminum, and still have integrity.
  7. sinizterguy
    25 Jul 2002
    Hmm ... yes get me a block of diamond and Ill see what I can do.
    Can we please stick to the topic.
    Looks like its Copper. I just wanted to make sure before I did anything.
  8. Haddy
    Haddy World Domination
    22 Jan 2002
    He ment out of those two but if you can get a diamond block Id love to see some pictures....Talk about some bling :eeek:
  9. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    The problem with a diamond WB is the cutting of the facets (for sparkle) and disguising the barbs.
  10. Guest-16
    Guest-16 Guest
    another problem with diamond is that only diamond can cut it.
    Good luck :p
    Glass? (heatproof pyrex) for bling bling factor?
    sorry ot :blush:
  11. sinizterguy
    25 Jul 2002
    Waterjets can be used to cut diamonds.
  12. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    are you sure :-\ i think not lol
  13. Supercool
    Supercool Gone.
    31 May 2003
    [ot]
    why not? you can also use special liquids that give a cleaner cut or something like that. google it :)
    Part of the polyalkylene glycol family IIRC
    [/ot]
  14. sinizterguy
    25 Jul 2002
    I am sure.
  15. Cheese
    Cheese Doc
    6 Oct 2001
    OT: You can turn a diamond into a large cloud of CO2 with a bit of acid too IIRC :)
    Out of copper or aluminium copper is probably better... though it depends how you're making it, aluminium is a lot easier to work with and may allow for finer details and more surface area to be exposed in your design.
    Rob.
  16. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    silver is soft, has high thermal conductivity, but is not relatively easy to obtain. but i would go with copper elsewise
  17. sinizterguy
    25 Jul 2002
    It's for a waterblock design for graphic cards, including RAM blocks as being discussed here
    http://forums.bit-tech.net/showthread.php?s=&threadid=36491
  18. 1398342003
    2 Sep 2002
    Just use copper, an all copper system will not corrode, and will perform better than an all alu system.
  19. Guest-16
    Guest-16 Guest
    probably polish, id doubt "cut". :eyebrow:
  20. sinizterguy
    25 Jul 2002
    It can cut ... it just takes longer.
    Diamond/carborundum dust is used to polish diamond and other gemstones.
