Cooling Copper or Alu ?
Discussion in 'Hardware' started by sinizterguy, 21 Jul 2003.
  1. Guest-16
    Guest-16 Guest
    k ill take ur word for it :)
  2. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    If you decide for copper, you have to buy a copper rad also.
    This is because of the galvanic currents that are created between different tipe of material (Galvani made a battery out of this?)
    So the question is there are copper rads resellers for watercooling purposes?
  3. Supercool
    Supercool Gone.
    31 May 2003
    most waterblocks are made from copper ;) so he can use any rad (most of which are copper aswell) because no other watercoolers have had any problems :)
  4. Guest-16
    Guest-16 Guest
    lead, zinc and 6-12M sulphuric acid iirc - classic car battery? :eyebrow:
  5. ChillingSP
    11 Jun 2003
    No, i was referring simply to contact between two different metals. Irrc this leads to a potential difference and hence to current.
  6. Guest-16
    Guest-16 Guest
    potential difference = voltage
    but you need a PD to move current, so techincally ur right i spose :blush: heh
    Yea, 2 metals not the same = ion movement = baaaaaad :nono:
  7. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    use watter wetter and put sacrificial anodes in, that will prevent any corrosion in a loop
