Modding Copper pens
Discussion in 'Modding' started by TX297, 18 Dec 2003.
  1. TX297
    TX297 Hey guys have you heard of seenly?
    28 Oct 2003
    Well, I'm having a hard time finding these. Radio Shack doesn't stock them, and I can't get out to a Fry's at the moment. I've already tried the "copper" colored Sharpie but my meter says it doesn't conduct electricity.
    Basically, my question is:
    What alternatives do you have for copper pens? I'm running tracks for my (ghetto) desk mod and I don't want to have to go through all the trouble of soldering tracks from my old LED cutoffs. I was thinking of using graphite when I realized that it wasn't conductive :duh:.
    I have already dug channels out into my desk, so could I just melt solder into it? I really don't want to do this though, as it would be a pain in the butt. Thoughts?
    By the way, I'll post pics when I'm done.
    Thanks,
    -TX297
  2. Black-Ice
    Black-Ice New Member
    2 Jul 2002
    so you carved little trenches into your wooden desk??? Hmm sounds interesting. I would say melting soilder would be an expensive task and it wouldn't condutc good electricity as it would be a cold solder...there would be clobs of stuff and it wouldn't be one contiunise line.... hm..... i would try a pen i guess. But than again depends on what the lines are going to...the resistance might not matter
  3. penski
    penski BodMod
    29 Aug 2002
    Use copper tape - readily available from craft stores. It's used for making stained glass stuff.
    Basically it's a roll of copper tape with one adhesive side :)
    *n
  4. TX297
    28 Oct 2003
    Dammit, I was at Hobby Lobby yesterday, even in the stained glass section! Thanks for the suggestions so far, I may go out and buy some of the stuff. I'll take a picture now and maybe upload it in a few minutes. In the meantime, do we have any other suggestions?
    Thanks,
    -TX297
    Oh, and by the way, I'm embedding LEDs into my desk. I've been using a bit of plexi to write on as my desk has textured paint all over it. Then I'm going to put the plexi over the top of the LEDs. If you take a nice blue LED and shine it on the green cut-out with the LED in it, it put a nice glow in the glue I'm using. I'm just filling everything in with glue. Told you it was ghetto.
  5. Black-Ice
    2 Jul 2002
    haha you should get the tape, fill in the trench thing cnalans whatever you wana call them...than when you have a buddy over and they put there hands on the deks or arm....zaaaaap!!! haha.
    But ya that tape would work so much better than soldier. What do you plan on hooking up and from where to where? I'm curious
  6. FullThrottleRic
    FullThrottleRic New Member
    15 Aug 2002
    Why don't you use wire?! :dremel:
  7. TX297
    28 Oct 2003
    Because it needs to be flush with my desk to fit underneath the plexi. I can't really dig the trenches that deep as I'm using one of those electronics screwdrivers and I don't have enough skin on my hand.
    Are there any readily available pens with conductive properties that I can get at arts & craft stores?
    Anyway, pic as requested:
    -TX297
  8. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Run solder wire along the groove and use a heatgun to melt it
  9. ConKbot of Doom
    ConKbot of Doom New Member
    2 Jul 2003
    If you have enough space to put solder in it, than you can get some bare 28awg wire, and that would work good. ( I think the wire in CAT5 is 28awg)
  10. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    is it just me who thought the thread title said "Copper penis", i need some more coffee :worried:
  11. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Could be a bit heavy...
    anyway: on topic: try di find a cable that has many wery thin wires inside (speakercables often have) and take out one of those and solder it on... Fill the grooves with epoxy or something afterwards..
  12. SJP
    SJP Member
    12 Feb 2003
    How about heated-window repair paint? (The stuff used for bridging Athlons laser-cut bridges).
    It's highly conductive, is paintable, and dries pretty quickly. It's also quite expensive (around £10 a bottleas I recall) but should be good for a lot of work.
  13. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Yes.
    I agree that thin wire would probably be the best bet. Using conductive pens and such is asking for trouble if you're using it over a fair distance (I imagine about 50cm or more?) since they're really designed for repairing bad PCBs etc.
  14. TX297
    28 Oct 2003
    I have no skin left on my hand
    Well, I dug the trenches a little deeper so I could solder my cutoffs into there. I have two of them hooked up so far, although I screwed up one LED by trying to move the legs over too far.
    Thanks,
    -TX297
    But now, does anone know where I can get these pens or something that will work in a similiar way?
  15. UnLoadeD
    UnLoadeD New Member
    2 Jan 2002
    SJP is right. Goto an autoparts store. Ask for a Rear Window Defogger Repair Kit. It's like copper based nail polish. Just mask off the areas where you don't want any, and then brush it on. Costs about $5-$6.
    peace.
    unloaded
  16. 3N1GM4
    3N1GM4 New Member
    23 Jun 2003
    why in God's name do you have a british flag on your desk if you live in dallas....
    i say go for the copper tape :blah:
  17. ouija
    10 Nov 2002
    Why would anyone want a British flag at all? ;)
  18. TX297
    28 Oct 2003
    I used to live in England and moved in 2001. I'm just being a bit patriotic, that's all.
    What do you call the bit-tech logo?
    I'm not sure what to get now. I think I may go for the copper tape--it seems to come in useful for optical drive mods.
    Thanks,
    -TX297
