Cooling Copper tubing
Discussion in 'Hardware' started by Makaijin, 17 Aug 2002.
  1. Makaijin
    Makaijin What's a Dremel?
    20 Dec 2001
    Ok,
    I plan to building a new watercooling system.
    I plan on using TECs this time around.
    But this time, I plan on mainly using copper tubing, and maybe use tygon on the ends to allow more freedom.
    Does anyone know where i can get more information as to working with copper tubing, like bending, soldering and stuff?
  2. Haddy
    Haddy World Domination
    22 Jan 2002
  3. Makaijin
    20 Dec 2001
    Well, I've read the procooling article, but it's not really deep enough as it only talks about how he cut some pipes and fit it in his pump?
    I would like a more in depth guide as to how to work with the stuff, like how do those plumbers bend the pipes with his knees? and how to solder joints together as well.
  4. Pug
    Pug What's a Heatsink?
    16 May 2002
    If you want to bend copper pipe without deforming it, you should use a proper pipe-bending insert (looks like a tightly coiled, long spring)
    See here
    In fact, check this article for a complete how to.
    And here's how to solder. :)
    Good old Google. ;)
  5. Makaijin
    20 Dec 2001
    Thanks for the links Pug.
    Now does anyone have a clue as to what size tubes to use?
    I was thinking of using maybe 3/4" as the copper pipes will be for the main channel, and with the ends fitted with barbs so i can run short lengths to the waterblocks.
    I will be cooling the CPU and the GPU, so somewhere on the line there will be T joints so to allow for more than 1 input/output on the lines.
    Another question, would it be ideal to run the CPU on pelt but straight water on the graphics card on the same loop?
    They will be split off of course, because i'm still deciding if i should pelt the GPU as well or not. I want to keep it on 1 loop so it doesn't complicate things too much.
  6. Risky
    Risky Modder
    10 Sep 2001
    The "Integral solder type" are quite handy if you don't enjoy this sort of work. In plumbing thay would be used where the joing is in a tricky spot. I wonder if you could get blocks with screw fittings to attacch properly to the pipe and get rif of the barbs.
    Would also look damm cool, but remeber the brasso for polishing :D
