copying hard drives
Discussion in 'Hardware' started by bAnTAi, 9 Sep 2004.
  1. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    drive to an empty (but formatted) one. Tried it in a dos prompt using the 'copy' command, but it only does the first directory, none of the folders. What command do i need? or do i need to use something else??
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    in winblows explorer:
    go to source drive
    ctrl + a
    ctrl + c
    go to destination drive
    ctrl + v
    or has it got to be in dos?
  3. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Dosen't Xcopy copy the folders also?
  4. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    Yea but you need certain switches to copy everything. i can't quite remember what they are as i did it on my work experiance in high school :hehe: But i think its /s /e /r /c /h /k. the e could be an a tho :confused: i can't remember
    Death
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    doesn't copy *.* do it as well? or is that just for files and not folders
  6. coorz
    coorz Miffed
    25 Apr 2003
    xcopy *.* /s d:
    assuming:
    you are in the root c:\
    where d: is your destination drive
    Why not doing it in Windows?
  7. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    I use the Maxtor drive copy. It works and i know my stuff got copyed correctly. Every time i try xcopy or some other dos command, it seems to miss some of the system files or somthing becuase my source drive will have a larger file size total than the new drive.
