Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Yeah it does look a time consuming part but does look in awesome perfect shape mate :jawdrop::rock::thumb:.
    The 1 thing I dislike most about only being happy with 99.9% perfection is it really kills a budget :wallbash::lol: the time consumption doesn't bother me too much with me having plenty of free time but breaking a budget does & I've gone way over budget already, in fact so far over I'd much rather not add it all up :eeek::waah::duh::hehe:.
  2. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks for the replies. :thumb:
    Yes, the radii are made with a round file.
    This file is tapered, but the greatest diameter of 7.8 mm is perfect for making these radii. This file is also fairly coarse, so it cuts very quickly. You need to always maintain perpendicularity to the surface you are filing in order to get a good finish. I think the position of the vice has a lot to do with being able to maintain square edges.
    Here's a photo of the inside edges done.
    Using a variety of files, any shape can be accurately made.
  3. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Nice work showing step by step process. Looking good:thumb:
  4. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Still drooling!
  5. Tonton Buddy
    Tonton Buddy What's a Dremel?
    8 Mar 2011
    Woow, u're work realized with files is amazing!!! :jawdrop:
    What is the thickness of the alu' tray? I've the impression that is a little bit thick no?
    Very very very good job Attila!! :thumb:
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Chunky good looking panel, most definitely built to last :D I'd guess it's 10mm thick :jawdrop::lol:.
  7. Attila
    22 Feb 2008
    Thanks guys. :thumb:
    Thanks. :thumb: Yeah these two parts together with the bottom tie plate are 8 mm. These parts need to be rigid and strong. The whole radiator assembly including the cover and the front of the shell with filter tray and intake grille will 'hang' off the front bulkhead. The rear part has to support the PSU 'hanging' below the central plate, all without flexing. Also, 8 mm is the minimum thickness that can be used for face to edge fixing with machine screws. Like Na'ir, this method of fixing will give a very strong and good looking method for making the main support structure. :)
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    So no need for any kind of bar frame supports, got it & yeah that sure does make for a super high quality clean look (the Attila trademark) love it :D:thumb:.
  9. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Sweet work Attilla :thumb:, I bet that took a while due to the thickness of the alu.
  10. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Man, I don't have the patience to hand file aluminum parts. Your work is truly outstanding.
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Very, very nice work.
    And, yeah - it's not too hard to file like that. Only, use the inside of your head, take your time, think about ways to create nice, straight edges, be quite critical as you go along and work slowly in order to be able to do quality checks on a regular basis.
  12. RonanH
    RonanH mod-envious
    30 Mar 2010
    Awesome. The painstaking attention to detail and patience to achieve those oh so so clean lines is astounding :eek:
  13. Attila
    22 Feb 2008
    Thanks mate. :thumb: Yeah I'm over the frame thing. :hehe:
    Thanks. :thumb: Yes it all takes time. But it's worth it in the end. :)
    Thank you. :)
    Haha, do I detect a note of sarcasm here. :hehe:
    Thank you. :)
    OK, once the two 'bulkheads' are almost finished, a few things still need to be done. The front part is significantly narrower than the rear. So I need to centre the two and fix them together. This is because, even though I measured, cut and filed very carefully, they are still not the same height. Also, some of the projections you can see are where the central plate fits. These have to be exactly the same height.
    Here you can see that one piece is about 0.5 mm or so too big. So this must be taken down to match the other part. In truth this is not really that critical but it's better to have them as close as possible.
    Next, these are the projections (not all of them) that hold the central plate. these are also not the same height.
    But to get in there, I need to 'mod' a file. :hehe:
    I've used this file on every project and it's very flat, so it will be perfect to even things up in here.
    Here you can see the difference in height.
    So carefully, these are all brought to same height, all the while continuously checking that the edges are square.
    It gets progressively more time consuming as all the surfaces have to be brought down to last little 'low' spot.
    OK, now the fun part where I can get a first glimpse of what the chassis will look like. Now I always like to take measurements directly from the work, so in order to find out how big to make the lower tie plate, I need to assemble the bulkheads to the central plate. Because the two bulkheads are different sizes, supporting the central plate and then 'hanging' the two ends of it is the best way to take the measurements.
    And once the measurements are taken (and checked three times) the lower tie plate can be marked up on some 8 mm plate.
    But I have to go and pick up Anika now. Back soon. :)
  14. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Great workmanship! Where do you buy your files? Is the flat one a simple mill file or is it one of those specially made for alu?
  15. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    The file God you are bro, period!
  16. jhanlon303
    7 Sep 2006
    Well Damn!!! That is how it's done? Next mod needs to be named Flawless Execution.
    john
  17. Cheapskate
    13 May 2007
    The cast iron set you have!
    I would have been very hesitant to chop my favorite file up.
  18. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Yeah I wonder too, how did you cut up your file? :eek:
  19. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Looks like an angle grinder with a cutting disc to me. That should do the trick, even on tool steel.
  20. SNiiPE_DoGG
    SNiiPE_DoGG Engineering The Extreme
    14 Apr 2009
    Files are about 10 bucks a pop from mcmaster, I don't think its a travesty to cut the handle off of one ;)
