Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    ah i see, i kinda get a vague picture, hope you could take a photo or quick sketch for clarification.
  2. Droih
    Droih Your too close if you can read this
    17 May 2010
    It just might have, alto for my first might be a rusty/destoryed case mod :naughty:
  3. shazza
    shazza What's a Dremel?
    24 Nov 2007
    Stopping in for my monthly bit-tech fix. Another wonderful Attila project - I'm convinced you are a sorcerer of modding, and your work is magic! Thanks for sharing.
  4. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    you okay Attila ? or just easter hols?
  5. Attila
    Attila still thinking....
    22 Feb 2008
    Hi shazza, nice of you to drop by. :) And thanks. :thumb:
    Nah, I'm fine. A bit busy though. :) Although I have been doing some work, but I've been stuck for a couple weeks on aesthetic grounds. :hehe:
    Managed to make the front struts. This was made from some 25 mm plate and I did not enjoy it at all. The filing took about ten hours. Also fitted the radiator, although I made the tabs big enough for the eight central mounting screws, it is rock solid with just four, so this will be OK.
    That big lump is held on with three M4 screws.
    Now it was time to think about the pads. I love the pads on Na'ir but I also thought that maybe something a little different will be good. To this end I played around with designs in sketch up and made some models in wood and even made some parts in alu.
    A hexagon based design.
    And after looking at lots of space craft and robots. I couldn't tell if I liked it or not, a quick polish on the unfinished part made it look closer to a final product and gave me a better idea. And I like it. :D
    But it's just damn hard (in my eyes) to beat those lovely round pads.
    So, as it stands now, I've asked my friend at work to make some larger pads of different design for the back. I'll make the rear struts and have a look at the result. The 'robot' pads look quite OK, if I was to go down this path then the rear pads will be bigger and of slightly different design as well.
    So I'll go away and play some more. :D
  6. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I prefer the round pads but none of them look bad.
  7. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    X marks the spot. The lunar lander x'ses make the case look space age. :thumb:
  8. RonanH
    RonanH mod-envious
    30 Mar 2010
    Awesome! Cutting and filing 25mm plate, you.are.insane!
    For the feet, I like the rounds but they need a slight spacer, similar to the robot ones. The square strut against the round pad doesn't fit right, the spacer might alleviate that a bit, or just round the front of strut, not something you'll want to do unless you;re 1000% sure though :)
  9. stonedsurd
    11 Mar 2009
    I like the X pads a lot.
    Great work :D
  10. nat83c
    nat83c What's a Dremel?
    25 Jun 2003
    What about, instead of being an X, with four "toes" how about just three "toes"
  11. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    That's what I was thinking, smaller round pads on a cross strut; overcomplicated though!
    I do like the simplicity of the round ones, but the crosses do look interesting... Tough choice.
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Go with the X shape. :thumb:
  13. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    I prefer the X'ed ones....
  14. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Its kind of hard to judge which feet look best without knowing the end look, but I don't care for the hex feet. The rounded and X ones both look good. Depends on which will go better with the intended final result.
  15. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    All 3 look wonderful. Will really depend on the case cover if they flow or clash with your secret design :D Nice work all around :thumb::thumb:
    Voigts beat me
  16. Nutman
    21 Oct 2008
    I think I mostly suggested the X feet, because the round ones look exactly like those used for Na'ir al Saif... we need to renew ourselves from build to build, mkay?
    Oh, and the hexagon ones are just not pretty to me, sorry ;)
  17. nathandanielmorris
    nathandanielmorris What's a Dremel?
    23 Jan 2011
    X marks the spot.
  18. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Yeah same here I think X or round ones are the best
  19. amagriva
    amagriva Minimodder
    13 Jun 2009
    Psst! Like all Jedi's he's too humble to promote himself but he has updated his personal site too! There you'll find the fabrication pics of the feet.
  20. SirNeikoOC
    SirNeikoOC What's a Dremel?
    7 Mar 2011
    Your work is amaziong, and inspiring! As a man who cannot afford to build my own computer, i only get to dream. Watching your work has become one of my new favorite hobbies! Very excited to see what this ends up looking like.
