Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Nexxo
    23 Oct 2001
    I like the hexagonal feet. But whichever feet you choose, they can only enhance the epic. :)
  2. bulldogjeff
    2 Mar 2010
    Have to agree it's the X shaped one for me. you got me thinking about some thing along those line s for my build..Thanks for the idea...lol
    It's all taking shape very nicely, could be a hat trick of MOTY's.
  3. Cheapskate
    13 May 2007
    I vote X -feet, (wait, is there a vote?)
    They give off a 'Space 1999' vibe, as does the skeleton frame.:D
  4. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Screw it- make them all & then just change them as the mood takes you ( make them screw on/off quickly via an embedded thread rather than needing bolting in from underneath ) :D
  5. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks for the comments guys. :thumb: It looks like the 'X' wins the popularity contest hands down. :hehe:
    Yep, you guys have hit the nail on the head. It does very much depend on the final 'look' of the shell. If it just stayed a 'frame' and looked very industrial and machine like, then the 'X' design will suit it well. But I'm guilty of having looked at this from a chassis only view point. In fact (without giving to much away) the shell will be nice and smooth with a satin finish, so it needs something smooth to go with that idea. I'm not overly concerned with repeating myself if it's only the case feet. But I still think that the round feet can be used in a novel way and I do think you will agree once I start to build the body. :)
    The 'X' pads will be filed away for future use.
    Last night my workmate Steve had enough time to make a pair of pads for the rear. The design looks simple but in fact took several hours and with many different permutations. These are larger in diameter and height, nice and chunky :D.
    They will be further apart than the front pads and will also be back behind the chassis. The reason for this will become clear once body building starts.
    I have some non work days coming up so the rear struts can be made then.
    Back soon. :)
    Waynio likes this.
  6. shah
    shah Minimodder
    29 Jan 2010
    I haven't been on the project logs for a couple of months and just saw a thread by Attila today!!!!!!! :duh:
    Very nice work as usual :thumb:. Will be reading the thread properly when I get home tonight!!!! :clap::rock:
  7. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    pure awesomeness =)
  8. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Your case feed fits perfect to the case.
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Blinking beautiful :D & OMG 25mm plate :eeek::D, bet that was some hefty filing session, marvelous stuff Attila :thumb:.
  10. Dragonite
    Dragonite Minimodder
    15 Feb 2011
    Just a question. Are you building a computer or a tank?
    Meaning this is just mental :D Mod on Attila. Gief us more :D
  11. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    now that is some fast forward progress :lol: and perfect as always :D
  12. Vaptor-x
    Vaptor-x What's a Dremel?
    28 Feb 2010
    All those machined parts looks great :thumb:
    But cant stop wondering how about the weight, it must start to weigh a few kg's ;)
  13. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    I prefer neither, honestly.
  14. RonanH
    RonanH mod-envious
    30 Mar 2010
    so you like them equally or dislike them equally?
    Personally I prefer the front feet to the rear ones, but I guess it will all have to be seen in the context of the final look, which to be fair Atilla has gotten spot on every time...
  15. PAL
    PAL What's a Dremel?
    27 Apr 2011
    Outstanding work and you are courageous my friend 10hrs on a 1 inch aluminium plate that is more patience than i got. I would go with the X feet to follow the big X on the main board.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    I'm sure the different styled feet will look sweet once it starts taking more shape as to what he has in mind :), I'm still puzzled how the heck did you cut the 25mm plate to basic shape, ah I've thought on & guess it must have been vice & hacksaw :D even just the cutting would have been a grueling task lol you Attila mate must just say what on earth are limits & just go & do things I find virtually inconceivable :D:thumb:.
    Truly amazing :jawdrop::rock::clap:.
  17. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I like the new feet better than any of the other versions. They look classy.
  18. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I vote for the invisible case feet struts :D
  19. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Invisible feet rulez! :rock: :lol:
  20. Attila
    22 Feb 2008
    Thanks for the replies and comments everyone. :)
    I had a few days off work so the last parts to be made from the really thick stuff were finished.
    These are the rear struts.
    Here's a photo of the pads to give you an idea of the size difference.
    The rear struts were made in two parts. I could make up all sorts of bulls**t stories why, but the truth is the design for a single part would not fit on the piece of 25 mm plate I had. :hehe:
    As it turned out, I am glad things went this way. I'm pleased with the result.
    Mounting holes were drilled and counter bored in the lower plate.
    The pads were counter bored beneath and a M4 thread tapped into them. Then the screws were put in nice and tight. This will allow the pads to be adjustable.
    And everything mounted.
    Then the lower plate was re-fitted to the chassis.
    And I'm happy, at least. :hehe:
    EDIT
    I just wasn't happy with the look of the front struts so the part was remade. This time with longer projections and room to shape the front. Also, the case was getting too long (front to back) so the spacers behind the fans were removed to reduce this length. I'm happy with this new design so things can progress further.
