Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    quality metal work....ta da dat ta daa... im lovin it (McDonalds)
  2. SNiiPE_DoGG
    SNiiPE_DoGG Engineering The Extreme
    14 Apr 2009
    I have the magicut file but I found that my nicholson aluminum file (that is to say designed for aluminum) seems to give faster removal despite being smaller. I'll have to give the magicut another go this evening...
  3. randomhero
    randomhero Minimodder
    6 Nov 2005
    It's always awesome and inspiring to see what you can to with very basic tools Attila!
    You make me confident that I can make something awesome when I get my workshop sorted (with a lot more than what you need to make awesome mods).
  4. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Ahhhh very nice Attila. So that cutting time is compared to 12" b*st*rd file ? If so I will have to get one to :)
  5. awratten
    awratten What's a Dremel?
    12 Jan 2011
    Looks Great.
    It almost doesn't need a shell, The frame looks so good.
  6. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks for the replies guys. :)
    After making the top tie piece and looking at it for a bit, the curve at the front was made more pronounced. Mainly to carry a slightly more aggressive look over to the front.
    Five separate, self contained removable panels will be made. An aluminium framework will be made for each of these panels, mainly for strength but also as a guide for the final appearance.
    Using various tools, the lines and curves are worked out.
    But while doing this, it was determined that the height of the rad/fans was still too high. :rolleyes: This was mainly due to the mounting posts on the fans.
    So they were cut down. The only problem with this was that the centred bolt pipe is attached to the top, so a great big void is left.
    After a trip to the local 'size of a football field' hardware store, I found something that fills the holes and re-centred the bolts. And it's a nice press fit.
    And the height is greatly reduced.
    Doing this allowed the nose part of the frame to be made.
    Then four supporting cross braces need to be made. This was first worked out in cardboard and then made in alu. I started with just one piece to get an idea of what is necessary before the other parts are made.
    Gets very cosy with the rad.
    Remember this framework is mainly for strength but the very slightest hint of the final shape is present.
    With the knowledge gleaned from the first cross piece, the others can be made from the same template and modified to fit.
    But I've run out of time so I'll file them another time. ;)
    Waynio and Cheapskate like this.
  7. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    looking great, and love what you did with the rad fans.
  8. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Looking epic as ever Attila!
  9. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    I like the kinda animal qualities it has, the feet remind me of something like a mammal standing. This is going to be cool, your attention to detail is magnificent. Are you going to make your own reservoirs?
  10. Cheapskate
    13 May 2007
    Still drooling, can't reply...
    -I also find myself googling local aluminum suppliers before I reply lately.:(
  11. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Wow awesome work Attila :thumb:, I'm amazed you can cut those peices out so neatly with a hacksaw
  12. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Good stuff Attila. I love seeing those curves.
  13. voigts
    voigts What's a Dremel?
    26 Apr 2006
    This gets more and more interesting
  14. alain-s
    alain-s Minimodder
    12 Jan 2011
    Really lovely work Attila u should make you're own case line :p
  15. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    do you just use aluminum tooling plate for your frames?
    Oh and its looking great :thumb:
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    As always very inspiring & looking lovely :D sweet design & build quality, but don't you just kind of hate it when you have parts like that to make & theres no other way to make better use of the material, I know I do but then again it'll always come in useful for something at another time :), bet you've got an awesome scrap pile :D.
    +rep
  17. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    i love the radiator frame!
  18. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    +1
  19. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Looks good, but I'm a bit baffled why many casemodders seem to give a crap about dust filters?
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    I can't explain how much I enjoy reading your logs dude, once this one is finished you should really think about turning them into a book :)
