Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Attila
    Attila still thinking....
    22 Feb 2008
    Sorry for the large interval between updates, but time is scarce and these parts are complex. I have been working but I'd rather hang on till there is more stuff for a decent update. ;)
    Thank you zero. :thumb:
    Ah, so that's what they are making. :)
    :hehe:
    Thanks mate. :thumb: I don't have much trouble with the countersinks to be honest. In places where there are many screws (like on one side of the intake for example), I start all the screws off first before driving them home just to avoid having to stress any of the opposite screws. ;)
    Thanks yogi. :) I get all my alu from Action aluminium in Dandenong. They also have stores in Thomastown and Bayswater.
    We're all waiting to see the result. :)
    Thanks Bill. :thumb:
    Thanks guys. :)
  2. NysoO
    NysoO Handcrafted
    2 Nov 2006
    So sick! :eeek:
  3. Stark.Jr
    Stark.Jr What's a Dremel?
    22 Mar 2011
  4. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    where did you get that from
  5. rayson
    23 Jul 2010
    i should do do that again just to add to attila's reputation
  6. Attila
    22 Feb 2008
    Haha, thanks guys. :thumb:
    Once the intakes were done they needed to be fixed to the frame. They also needed to be easily put in from behind the front assembly once the body is done. So some brackets were made to fix to the frame. These double as fixings for the mesh grille.
    And then some mesh was cut to size and the edges bent over for strength. I just couldn't find the mesh I wanted anywhere, so my desk was cannibalised and a panel removed for the greater good. :hehe:
    And this mesh looks very nice.
    Then some front 'fenders' needed to be made. These were cut from some 1.6mm sheet.
    The fixing tabs were scored before a curve was put into the parts.
    And then a curve was put in to match the curve of the lower crosspiece.
    And the tabs bent over.
    And fitted.
    Then a rough drawing was made of the fin arrangement.
    And an angle cut into the front of the fenders.
    Although in my drawing the fins were to come off the curve of the front and then straighten up, I changed my mind and angled the fins inwards. This allowed the lower intake to be framed nicely by the front pads and also reduced the projection of the front. You can see what i mean by the cardboard model.
    So a template was made and the fins cut from some 3mm plate.
    Then some supports were cut from 8mm plate.
    The supports needed some slots for the fins.
    Then some notches were cut into the plates until they sat 'just right'.
    And I'm very happy with the result.
    The fin supports will shaped nicely and a drilling needs to be made through these to fix the fins.
    Back when I can.
    Marcos_Viegas likes this.
  7. Nexxo
    23 Oct 2001
    First! :D
    Love how all the parts interlock and create a smooth whole. Great work as usual.
  8. Herodj95
    Herodj95 What's a Dremel?
    9 Sep 2011
    I'm a new user but i have see all your works! Congratulation, you are very precise on your work! :thumb:
    Fantastic job Attila! Congratulation! :thumb::clap:
  9. Aniki Stinson
    Aniki Stinson In cornichons we trust.
    5 Apr 2010
    " I love the smell of Attila's updates in the morning. "
    :lol::clap:
    Remember remember, it was a couple of years...
    You're not only one of the best modder in the world, but you also draw, and are also talentend in it !
    Attila, as one of your biggest fan (yes, I am a 1730 mm fan and I won't fit in none of your cases), may I ask you a question ? [Oh, I can, really ? Yeaaaaaah !]
    Would you mod the Joconde and make it much better if I bring her to you in Melbourne ? :)
  10. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Fantastic work again Attila, fits beautiully together.
  11. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Yay whenever there's an update a rainbow shows up in the sky and life becomes less miserable. :D
  12. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Beautiful work but it must weigh a ton. :p
  13. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    I really dont know what to say anymore. Your work its phenomenal and I agree that you are the best modder in the world by far. You are a true inspiration for all of us as we want to become better and better, well done my friend I bow before your skills! :)
  14. Combatus
    16 Feb 2009
    Indeed a great thing to read through on a Saturday morning! It's looking fantastic Attila.
  15. The boy 4rm oz
    10 Apr 2008
    OOOOOOOOOOOOOOOO love the fins :D.
  16. robi09
    robi09 What's a Dremel?
    20 Jun 2011
    oh man.. i'm in love !
  17. y0gi
    y0gi What's a Dremel?
    23 Nov 2010
    Freakin' awesome dude! That's just sick!!!!!!!!!:rock:
  18. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    This mod just getting better and better :) Dude u RocK
  19. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Just as I thought I kinda got the hang of the thick aluminium filing overkill the u come and set me back a few steps again :(
    But that's a good thing! :) keep it up! It's look brilliant!
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Damn the floor is cold on my jaw! I was wondering when that sheet roller would be coming out again :D
