Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Guest-23315
    Guest-23315 Guest
    Just glorious.
  2. l3p
    l3p www.^.nl
    1 Nov 2010
    It's already my most favorite case ever...
    Somehow I always try to imagine what his next step will be.... every time it's even better then I expected. :jawdrop:
  3. dirky90
    dirky90 Minimodder
    19 Mar 2012
    unbelievable work, looks so good!! words cant do it justice.
  4. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    When Attila starts a log, the napkin he scribbled on should be used as the place holder on MDPC...
  5. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    +rep - this is the juice of life
  6. Tangster
    23 May 2009
    I'll be here, with a napkin to absorb my drool.
  7. nat83c
    nat83c What's a Dremel?
    25 Jun 2003
    Another awesome update from the master himself.
  8. jhanlon303
    7 Sep 2006
    Napkin, bib, towel, depends. Bring it! I ready. Awesome.
  9. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    thats what i would call symmetry! its hard to get two flat panels the same, cant dream of the tedious procedure to get two riveted panels mirrored! >.<
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
  11. ZetKen
    ZetKen What's a Dremel?
    4 Apr 2012
    :thumb: looking very nice
  12. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks for the replies everyone. :)
    I've been thinking about the hinges for quite a while now, and I think I've worked out a scheme that allows the doors to open in the way I want without any fouling.
    But before work can start on these, the top panel needs to be made up.
    As with the front and rear sections, the top needs to be removable as one complete unit. This is because all these sections will be painted, and in the case of the front panel, access needs to be available for fitting and servicing the radiator.
    A frame needs to be made to hold the two sections that will cover most of the top. To aid in working out what is needed I quickly made up a rough model (in aluminium) of what I envisage the top will look like. I also needed to test how the sheet will follow the compound curves up there and whether this can be accomplished without rolling the sheet.
    A cardboard template was made first.
    Then the shape was cut from 1.2mm sheet.
    The bends required were made on the bench and with the brake.
    And then I can see that the part can be made to fit this area and bend in the required way. I can also work out how a supporting frame needs to be made.
    You can see here that this piece fits over the central main tie beam and this is not was is needed here. So the top will be made in two parts. The important thing is that my idea will work and I can see how the frame needs to be made.
    So after some thought I decided to use some left-over plex from Na'ir. I'm thinking this will be strong enough to contain the top even though this will be under tension.
    Using the files I normally use for alu made the filing very slow, so I tried using a wood rasp. This required a fair bit of force to use but cut through the plex very quickly. I could then clean up with the finer files.
    And thats the first part done.
    To get the angle on the top edge, first I used a marker to cover the surface so I could see how the filing was progressing. Care needed to be taken here as this angle changes towards the back. So constant checking was needed to get this right.
    Then the front and rear members were made up.
    And that's the basic frame.
    And then the holes were drilled and a little mounting plate made for the rear. Here it is mounted to the main central tie.
    New panels were marked out and cut.
    Then a straight edge was used to get the bend lines. It's important to do this in place because the front is much narrower than the rear, so these lines must follow the correct angle.
    And screwed in place for the final trimming (these parts are slightly oversize).
    Back soon. :)
    rak500 and Waynio like this.
  13. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    ... (have no words) ... :jawdrop:
  14. lakisss
    lakisss I know what a dremel is...
    28 Mar 2010
    just epic!
  15. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Learning so much, just be looking at it !
    Top dog !
  16. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    How you can have no scratches with no protection on your plexiglass ?!
    You know the expression "who's your daddy ?", in my case I already find my daddy -> can I call you dad ?!!
  17. jhanlon303
    7 Sep 2006
    Such abilities and the patience to create perfection.
    I watch and am in awe again!
    john
  18. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    There goes my self esteem...
    truly amazing.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Superb creating Attila, very nice top, goes excellent with the rig.
    This is why you inspire me & am sure many others so much, regular tools forming irregular awesomeness, over the time I've viewed your creations you have opened my eyes & imagination more than I thought it could, you helped uncap some limits I thought were there. :D:dremel::rock::clap: rep
    Bet the hot tub is totally awesome after a hefty filing session, much needed upgrade. :D
  20. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I always love reading your updates! This is looking fantastic! :thumb:
