Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Evenge
    Evenge Minimodder
    16 Sep 2006
    Or they motivate you to start planing something! :naughty: Honestly I've been thinking and sketching a new project for 2-3 months now and must say this is truly inspiring work!
    Keep up the good work man! :)
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    That's a real shame about the side panels. Could you not have used something like a gas spring to support them rather than letting the hinge take all the weight?
    Coming along nicely though. Genius idea for the sanding tool, might have to steal it ;-) Can't wait for the next update :)
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Attila pushing his own limits higher as well as the usual quest for sheer perfection + water cooling = many jaws scraping along the floor. :lol::rock:
    And at the same time is awesome motivation to keep busy modding, it's my birthday & it was an awesome present to see an update on this as well as seeing another modder become a dad & my focus & energy back to regular level & the steam sale actually being an awesome one :jawdrop: happy day is happy day :D, been on the edge of asking if things are still rolling so awesome timing for the update. :D:clap:
    Progress is looking fantastic & you already proven you can make nice home made water blocks so I'm not disappointed you chose manufactured ones, don't want any water cooling disasters happening to your first water cooled masterpiece due to the types of metals. :)
    I like the pin solution you made up, I was going to use aluminium rods like dowel joints but this looks a better solution which will be more user friendly, shame about the hinges not being ideal for this but you'll work something nice out I'm sure. :)
  4. Cheapskate
    13 May 2007
    I have to say Nexxo nailed my opinion exactly. I bet whatever you have planned will be truly delicious, though.
  5. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    I recommend using 3M Marine Filler or there MarGrip2 on aluminium. I have seen that off "cheap" brands can produce a wavy paint finish. I recommend wet sanding down to 1500-2000 grit, most people stop at 1000. Good job on those rivets. I wanted to use them in SSR-X but the tightness of the design just would have been prohibitive.
  6. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Great work as always and very nice of you to share the info of what has been happening. A solution sometimes takes a while to resolve. I like the simple approach taken, light weight and very clean. :)
    Good luck with the prep work, you'll have it done soon. :D
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Grat continous work theye, i hoped that you would keep the ALU-finish but maybe some paint will make it look eaven better :)
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    That homemade retention plate just earned you some rep, good sir. Well played.
    The side panel looks weird and complicated - I like both things. No wonder you had problems making gull wing doors from that.
    Oh... and.... are you drinking while modding? ;)
  9. Nutman
    21 Oct 2008
    Oh, and happy birthday to Waynio. ;)
  10. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks. :) Yes I like the idea of exposed rivets, but not these kind of rivets and not on this build. A couple of years ago I was planning a raw alu build and looking into making my own rivets. Solid rivets made very small so they would be more to scale. I was looking at getting some 1 or 2mm alu wire and making a steel form so I could hammer rivets with a button head. But I went past that idea. It's still out there though. ;)
    Thanks ZiiP. :thumb: No hangover is a very nice start to the weekend. :hehe:
    No internet for a day. :eeek: Haha, thanks mate. :thumb:
    Thanks Bill. :thumb:
    Thanks AnG3L. :thumb:
    Thanks. :)
    Thank you. :)
    Thanks. :) The problem wasn't the weight. These panels are quite light. It was more an engineering problem, and in the case of commercially available hinges that worked the right way, a matter of scale. They were just too big and bulky.
    Thanks Wayne and happy birthday. :clap:
    Thanks cheaps. :thumb: This case will be very smooth and sleek, with a nice metallic finish. It's supposed to be evocative of super cars (as you guessed a while ago). ;)
    Thanks. :thumb: I've used these kinds of filler in the past. A lot actually, on cars. In this case, the build film on these panels is about a millimeter at the most, in the lowest of low spots. This filler adheres well and dries tough. Also, this is a PC case, it will spend most of it's life in an environment with a temperature variance of 10 degrees at the most. It will never come into contact with moisture or direct sunlight, and doesn't have to drive over bumps and potholes. This stuff is easily up to the job. I've seen the wavy finish you describe, on cars as well as a PC build or two, but this is entirely due to poor workmanship. Oh, and it wasn't cheap. ;)
    Thanks Craig. :thumb:
    Thanks, yes it's paint this time and I hope it will look delicious. :hehe:
    Thank you. :thumb: Yeah the problem wasn't because of the shape of the panels. The shape was (in part) deliberately arrived at for upwards opening. See above. :)
    rwb97 likes this.
  11. paultan
    paultan R E V E N T O N
    22 Jan 2010
    I'm seeing MOTY for the grandslam! :)
  12. iD2
    iD2 Minimodder
    25 Mar 2012
    very awesome , i watched your build log again and again and again..... :D
  13. Ilias78
    Ilias78 What's a Dremel?
    23 Jul 2012
    Fantastic and very inspiring work my friend Atilla. Keep it up! :)
  14. Frido
    Frido Minimodder
    19 Apr 2007
    Sorry for bumping - but has anything happened since there's no news?
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks Frido. :)
    You really could put that quote with the dremel smilie on a t-shirt & wear it proudly while modding. :D
    Thanks to the bump Frido did I had another look at his last update & now I'm off to mod on with enthusiasm. :D:dremel:
    Enthusiasm is so important to mod on, not just determination, without the enthusiasm it's sometimes just too dull, really need a slightly crazed twinkle in the eye called enthusiasm. :hehe:
    Needed that. :D:thumb:
  16. rwb97
    rwb97 Addicted to modding
    1 Jul 2012
    I honestly am speechless. Truly inspiring, INCREDIBLE +rep all the way, your craftsmanship makes me happy, and want to put more time, effort and care into my work.
  17. Attila
    22 Feb 2008
    Thanks for the replies. :thumb: I'm not far away from an update but the body work has taken an age. I've had to work on all the panels, in place on the chassis, to get everything aligned nicely. Still some work to do on the gaps. It's nearly ready to get the panels off and sand down the chassis for anodising. Here are some pics but I'll have a proper update soon. ;)
    Oh, this blue/green/blah colour is primer and it looks yuk.:hehe:
    Johnny71 and Editor22 like this.
  18. FatPandas
    FatPandas What's a Dremel?
    4 Sep 2012
    Nice work so far man. Massive respect for filing all your components, I can appreciate how long that takes.
    I honestly like the aqua marine colour, especially something with a matt finish.
    Any chance of a full body shot or do you not wanna ruin the surprise?
  19. J-Lyons
    J-Lyons What's a Dremel?
    7 Jul 2012
    That colour is lovely, it is not yuk, you cat.
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Saw the shots and thought OMG Atilla is not going to anodise it! END TIMES!
    read the post and balance is restored :D
    Looks like some stunning angles by the way mate!
