Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    holy crap! Awesome!
    also the label on your package... :lol:
  2. Guest-23315
    Guest-23315 Guest
    Sweet Jebus...
    Also, that guys log is hilarious. We should try and get him to come and post over here, he'd go down an absolute storm.
  3. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    The polished bits look sweeeeet. Will the finish stay like that, or will natural anodizing (oxidation) eventually ruin the polished look?
  4. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    When you get to that point... You KNOW you are modding LIKE A BAWS! :thumb:
    Not gonna say anything about those polished parts, you sick sick person! :lol:
    Ohh... Btw, I am... May I lick them? :p
  5. Guest-56605
    Guest-56605 Guest
    Jasus :jawdrop:
    Custom shaving mirrors by Attila :D
  6. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    those parts are just.... perfect!
    and wonderful packaging buy the guys :D
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    thats an awsome pacage, i think that the mirror finish could be better !
  8. Nutman
    21 Oct 2008
    Ladies and gentlemen, I give you: Angel OD at his best.
    :D
  9. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    What I would like to know is how are you holding in the triangular shaped fins? I see one of them has screw holes, but what about the others? What kind of crafty witchcraft are you up to Attila?!
  10. wratterus
    wratterus What's a Dremel?
    2 Jun 2011
    Matt's worklog is a crack up, especially those shopped photos of his girlfriend!
    That alu is looking stunning, this build is really coming together. :)
  11. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    :jawdrop: Brilliant......
  12. alain-s
    alain-s Minimodder
    12 Jan 2011
    Never could have Imagen that it would look so awesome after the polish. I am happy that I could help also that U 2 work something out for the copper pipes. :D
    The blog from Matt is idd really nice love the comics. ^^
  13. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks. Believe it or not but they are being used. :)
    Thanks. Yeah everyone should check out that link. :)
    Thanks. No, Na'ir al Saif still looks very shiny. I can't say it's as shiny as when it was done but it still looks good. ;)
    Thanks mate. :thumb: I don't get the 'ping pong ball' stuff, but I'll take your word for it. :)
    Thanks a lot ZiiP. :)
    Thanks. :)
    Thanks stone, yep they actually do look 'different'. :thumb:
    Thanks you. :)
    Thanks mate. :thumb: Nah, it only took about fourteen hours to sand and polish. :eeek:
    Thanks jokkos. :thumb:
    Oh man, that would ruin the finish........OK, just one lick then. :lol:
    Haha, too kind. Thanks. :)
    Thanks. :thumb:
    Everything 'could be better'. ;)
    Not witchcraft mate. Very simple actually. It's hard to see in the photos, but the slots in the support columns are not cut square. Only by a very small amount. So what I have is an interference fit. That's why I had to be very careful when assembling after polishing. The fins needed to be lined up exactly and then pushed home. They are very difficult to remove.
    Another 'locking' feature, if you look at the sides of the fins you will notice that the profile is wider at the back than the front. This is because of the curve in the front section of the case to which this assembly mounts. The whole assembly, as you saw it in the previous update, slides up from underneath and is fixed by the two mounting screws. Once this is in place, none of the fins can move forward. They are locked in place by the shape of the front section. ;)
    Thanks. :)
    Once again thank you very much for helping me out Alain. :thumb:
    So I can put away this stuff for at least another year. :hehe:
    The mesh for the intakes were sprayed with, etch primer, two coats of grey primer, two coats and a mist coat of 'gunmetal' metallic and two coats of clear. Phew. :lol:
    And I don't know about you, but I think this looks terrific damn it! :dremel:
    Back when I can. :)
    Waynio and The_Crapman like this.
  14. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    :jawdrop: That is stunning work :dremel:
  15. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    this is pure class modding on a whole other level.
  16. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Mod of the Century! :thumb:
  17. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    OH GOT THAT MESH AND THE GRILLS , Looks amazing ! im in love =)
  18. The boy 4rm oz
    10 Apr 2008
    Mesh looks awesome, polishing awesome as allways. Your work is absolutely top notch Attila. And the most remarkable thins is you do it all by hand.
  19. sixfootsideburns
    6 Feb 2009
    Very crafty. I hadn't noticed the taper that you talk about but it definitely makes sense now. I ask because a case I started designing about a year ago (and put on hold because of other projects) uses front fins. I had a totally different solution that would accomplish almost the same thing. In the end I may just end up doing a hybrid of your solution and mine to accomplish what I'm hoping will be a "zero-screws visible" result from the outside of my fins
  20. Paslis
    Paslis Minimodder
    13 Jun 2011
    Awesome work Atilla i simply love the polishing. :thumb:
