Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    With all the alu work that you do, you REALLY need a CNC Router.
  2. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Some good information here.
    Essentially, if you put copper and aluminum together, you will dissolve the aluminum. This doesn't take into account the reactivity of the water that you put in, however. Yes, it will be 'pure' water initially, but as soon as it touches anything it will start sucking up ions, making it more and more conductive.
    Edit: A much easier to read table.
    Attila likes this.
  3. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    @nutman: he does it all by hand, that's what makes him so amazing. :)
  4. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    All aluminum system end of topic:)
    Hi Attila very nice redo. Maybe some grooves or channels around the block would fit with your build:)
  5. Attila
    Attila still thinking....
    22 Feb 2008
    A big machine would be great. :hehe: But this would have it's down side, which I wont go into here.
    I've seen lots of those charts but not the two you've linked to here. The second one is particularly helpful. It seems, if I'm reading it right, that copper is a big :nono:, but brass is within acceptable limits. This could mean that the radiator can stay. :)
    Thanks mate. :thumb:
    Thanks Craig. :thumb: Yes there is quite a lot of surplus material to get rid of. See below. ;)
    I had enough time (made enough :hehe:) to finish the channels and water feeds today.
    Drilling the holes first made routing much easier.
    Some of you may not know what I'm using to cut the channels. I'ts a Ryobi trimmer that takes 1/4 inch bits. With a 10 mm carbide bit.
    Dropping down vertical is a hit and miss affair so there are some rough spots, but I'm happy with the result.
    Then the feeds are drilled (10 mm).
    Now the shaded area is all useless material, so I may as well try some decoration on the way to removing it. If it works it can stay, if not it'll go. :)
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Attila you always amaze me & inspire me with your awesome manual ways :D, sky's the limit it seems :rock::thumb:.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Rough spots? Sure... :eyebrow:
    Dude, this looks amazing! :rock:
  8. craig - toyoracer
    1 Mar 2011
    Nice, now I see other side maybe some steps along that "V" :)
  9. Cheapskate
    13 May 2007
    Daaaang! I never built up the nerve to hand rout aluminum. any problems with it trying to grab?
    I pretty sure you removed the excess already, but some perpendicular fins sawed into that area would be cool.
    -Just promise us you will mount the whole thing in a jig to do it...
  10. Nutman
    21 Oct 2008
    Yeah, it looks like Attila went about using the press drill and subsequently the router WITHOUT securing the piece in a jig - madness. Think about it breaking your fingers if not secured properly.
    You must have the fingerstrength of the Hulk.
  11. Vaptor-x
    Vaptor-x What's a Dremel?
    28 Feb 2010
    This mod looks amazing! :thumb:
    How could I have missed it....
  12. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    How did I not find this beforehand? A new Attila mod, no less?! Subbed!
  13. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Impressive work with that handheld router :thumb:
  14. Obsidian Rift
    Obsidian Rift What's a Dremel?
    19 Feb 2011
    Hi Attila! I am a admirer of your awesome metal work and attention to details! (been going tru all your work logs n website for the past 3days n counting... :D) You've inspired me to start working on my scratch build... in ALUMINIUM of course!! Keep up the good work!! :rock:
    **Btw what drill press would you recommend/ you using? Thanks! :dremel:
  15. Attila
    22 Feb 2008
    Thanks a lot guys. :thumb:
    The router is hand held (very firmly with both hands). I haven't had any problems with it wanting to do it's own thing. The main problem is lowering the bit into the work, very hard to get it to go into the cut without taking a chunk out of the side.
    My drill press is set up 'just so'. This means, basically, that anytime the drill gets stuck in the work, the belts just 'slip' and I can turn off the drill and extricate the work piece from the drill bit. So, yes, I do hold most things with my left hand while drilling. As with anything to do with power tools., ALWAYS give 100 percent of your attention to the job at hand.
    I do not recommend doing anything as described above.
    @ Obsidian Rift., The drill press I bought about a year ago is a Chinese generic model made for a zillion different companies that just put thier name on the outside. You will be able to buy one like this or similar, anywhere in the world. This one cost me about $370 but I just received a catalogue in the mail, and this model is on sale for $280. Considering the good quality and the amount of materials and work that has gone into this, these prices are amazing. This drill press is a floor standing model, is big, heavy and well made. Here are some pic's.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  16. ianclowe4c
    ianclowe4c What's a Dremel?
    17 Jul 2004
    This is some fantastic work. I wish I had the tools that you do in order to do some mods. Sadly, I must just use my dremel at the moment.
    -ianclowe4c
    Nutman likes this.
  17. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Wow Great metal job. I like your style :)
  18. Obsidian Rift
    19 Feb 2011
    Thanks for the reply! Will search tru the "zillions" of China supplier now! ;]
    Really looking forward to your next update! Cheers!
  19. Pelihirmu
    Pelihirmu What's a Dremel?
    2 Jan 2005
    +1 for that, sadly :( And don't manage to find time anymore for modding or extra money :sigh:
    But great job so far! :thumb: Subscribing :eek:
  20. Tonton Buddy
    Tonton Buddy What's a Dremel?
    8 Mar 2011
    Hi!! :)
    I'me really fan of ur idea!!
    Place the GPU parallel at the motherboard is great!!! :thumb:
    I shall be watching, keep up the good work. :thumb:
