Overclocking Core 2 Overclocking
Discussion in 'Hardware' started by [KNIGHT], 26 Jan 2010.
  1. [KNIGHT]
    [KNIGHT] What's a Dremel?
    8 Dec 2009
    I saw the thread about i7 overclocking and i thought that core 2s also deserve to have a thread like that. So use this thread to post your core 2 duo, quad & extreme overclocking results.
    Motherboard :
    Motherboard chipset :
    Memory Type :
    Capacity :
    Memory timings :
    RAM frequency :
    CPU type :
    Model :
    Stepping :
    Revision :
    CPU cooling method :
    CPU cooler :
    FSB frequency/Bus speed :
    Multiplier :
    CPU voltage :
    Core Speed :
    Most of these info can be obtained from CPU-Z
  2. [KNIGHT]
    8 Dec 2009
    Here are my results
    Motherboard : Intel DP45SG
    Motherboard chipset : P45
    Memory Type : DDR3
    Capacity :2GB
    Memory timings :8-8-8-20
    CPU type : Core 2 Quad
    Model : Q6600
    Stepping :B
    Revision : GO
    CPU cooling method : Air
    CPU cooler : Stock CPU cooler
    FSB frequency/Bus speed : 334
    Multiplier : x9.0
    CPU voltage : 1.3250
    Core Speed : 3.006Ghz
  3. J!n
    J!n That's aperture science
    7 Nov 2009
    Motherboard : Asus P5Q-PRO
    Memory Type : DDR 2
    Capacity : 4GB
    Memory timings : 5-5-5-15 Duel 2T CMD rate
    Model : Q6600
    Stepping : B Revision : GO
    CPU cooler : Freezer 7 Pro
    FSB frequency/Bus speed : 380MHz
    Multiplier : x9.0
    CPU voltage : 1.376V
    Core Speed : 3420.2MHz
    Been running like that since January last year when i built it
  4. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Motherboard : Asus Rampage Formula
    Motherboard chipset : X48
    Memory Type : DDR2
    Capacity : 8192MBytes
    Model : Q6600
    CPU cooling method : Water?
    CPU cooler : Corsair H50
    FSB frequency/Bus speed : 400MHz
    Multiplier : x9.0
    CPU voltage : 1.48V
    Core Speed : 3600MHz
  5. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Anyone still toting a Core2 is gonna have either a Q6600 or a E8x00...
  6. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    errr no. :duh:
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Motherboard : Asus P5K Premium
    Motherboard chipset : P35
    Memory Type : DDR2 800MHz
    Capacity : 4GiB
    Memory timings : 4-4-4-12 2T
    CPU type : Intel Core 2 Quad
    Model : Q6600
    Stepping :B Revision: GO
    CPU cooling method : Air Cooling
    CPU cooler : Xigmatek HDT-S1283
    Multiplier : x8
    CPU voltage : 1.328
    Core Speed : 3200MHz
  8. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    he is pretty much right with that, most people have either of those. Maybe the odd E5200 and Q9x00 CPU, but many will be Q6600 and e8x00.
    And some might have the super rare E7400! :jawdrop: lol!
    Face it this thread is out of date by 2 years easy, making it rather pointless IMO.
  9. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    E6600? E4400? There were loads of great C2D's! :thumb:
  10. Burnout21
    9 Sep 2005
    i am not saying there weren't great ones, but on mass most people now have Q6600's
  11. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I had a E4400, got to 3GHz on stock cooler, evil little chip, also had an E7200, even rarer than the E7400 :p
  12. TheHalfWit
    TheHalfWit Call me dino
    25 Aug 2009
    Motherboard : P5E3 Pro
    Memory Type : DDR3
    Capacity : 4GB
    Memory timings : 9-9-9-24
    CPU type : Core 2 Duo
    Model : E8400
    Stepping : E
    CPU cooler : Cooler Master V8
    FSB frequency/Bus speed : 400 / Bench OC: 500
    Multiplier : 9
    CPU voltage : 1.34 / Bench OC:1.6
    Core Speed : 3.6Ghz / Bench OC: 4.5 Ghz
    Note, I am one of the few people to have built one recently and I'm likely to get a bit of flack for it, It's just I managed to pick up parts of it for free or real cheap, only problem is I think I killed the PSU already... Thats why I'm running it at 3.6 vs 4.3 all the time. I have plans to switch up to intels next generation of hardware when it comes out I think, I mean after I3/I5/I7/I9.
  13. wyx087
    15 Aug 2007
    my old system:
    Motherboard : Abit iP35 Pro
    Memory Type : DDR2
    Capacity : 8 GB
    Memory timings : 5-5-5-18
    Model : Q6600
    Stepping : G0
    CPU cooler : Thermalright Ultra 120 Extreme
    FSB frequency/Bus speed : 378 Mhz
    Multiplier : 9
    CPU voltage : 1.37v (there about, can't remember exact figure)
    Core Speed : 3.4Ghz
  14. ashwinc
    ashwinc What's a Dremel?
    28 Jan 2010
    hello thought i'd post and join in :) 9 months old and not a hint of upgrade envy.
    Motherboard : rampage formula
    Motherboard chipset : x48
    Memory Type : ddr2
    Capacity : 4gb
    CPU type : e8400
    Model :7 rev E0
    Stepping :A
    CPU cooling method : air
    FSB frequency/Bus speed : 1700 / 425
    Multiplier : x9
    CPU voltage :1.272v :thumb:
    Core Speed : 3825
  15. she'shighvoltage!
    she'shighvoltage! What's a Dremel?
    24 Sep 2009
    I'm running a Q8200 ;]
  16. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Does the steam hardware survery suggest this? Or you read it on Tomshardware? :p
  17. Burnout21
    9 Sep 2005
    personal experience of every smeg head that posts on these forums and the years i have put into the hardware section alone.
    Alot of people ran with E6600 before the sudden price drop on the Q6600 around the summer of 2007, pretty much everyone ditched there E6600 to add another 2 cores, that is if they weren't running the horribly buggy nforce 680i motherboards, which took about a million bios updates to get stable with Q6600 yet alone do any overclocking.
    Yes some people may have had other CPU's from the intel stable, but on mass people have purchased the Q6600. A bit like now how people have bought the i7 920, and the i5 750, there all best bang for buck CPU's.
  18. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    Motherboard : Rampage Modded Maximus Formula SE
    Motherboard chipset : X38
    Memory Type : GSkill Pi 6400
    Capacity : 4GB
    CPU type :
    Model : Q6600
    Stepping : G0
    Revision :
    CPU cooler : Swiftech Apogee GT
    FSB frequency/Bus speed :450
    Multiplier : 8
    CPU voltage : 1.475
    Core Speed : 3.6GHz
    Most of these info can be obtained from CPU-Z[/QUOTE]
  19. tk421
    tk421 Idiot.
    15 Jan 2002
    Motherboard : MSI p43 NEO-3f
    Motherboard chipset : p43
    Memory Type : Hynix oem pc2-6400
    Capacity :2x 2gb
    Memory timings : 5-5-5-20
    CPU type : c2d e7400
    Model :e7400
    Stepping :a
    Revision :r0
    CPU cooler :CM TX3 w/ 2x 92mm (thermaltake "open" pusher on rheo, CM stock fan pulling on PWM)
    FSB frequency/Bus speed :333x4
    Multiplier :10.5
    CPU voltage :1.1v
    Core Speed :3.5 ghz
    not sure what makes the e7400 rare ... we have over 200 of em at work. Dell is now shipping us machines with the e7500 in it, but newegg still has the 7400's for around $115.
    machine has been running @ 3.5ghz since i built it in September. Haven't really pushed it - a stable, cool 25% overclock is plenty for me.
    and for the younger generation around here - not all overclockers rush out and buy the latest, greatest hardware the day it comes out. some of us have families to feed, and overclock to make budget equipment perform to the best of it's abilities. the last rig i built completely from scratch, with the intention of overclocking, was a athlon xp 3000+ rig.
  20. [KNIGHT]
    8 Dec 2009
    Memory Type : DDR3
    Capacity :2GB
    RAM frequency : (Cant remember)
    Model : Q6600
    Stepping :B
    Revision : GO
    FSB frequency/Bus speed : 356
    Multiplier : x9.0
    CPU voltage : 1.3125
    Core Speed : 3.2Ghz
