Motherboards Core balancing and AMD
Discussion in 'Hardware' started by Aragon Speed, 14 May 2010.
  1. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    I have a Phenom II X4 940 BE, and a Biostar TA790GX3 A2+ Motherboard (With the BIOS update to support the Phenom II's). (http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=376)
    I am trying to find out what the BIOS setting called 'Core balancing' does.
    Now as usual the motherboard manual already assumes you know what 99% of the BIOS settings are and does not actually explain what they do (at least not in anyway that is meaningful to someone who hasn't a clue what they are supposed to do), not to mention the ones it misses out completely.
    I have tried looking it up on google, but all I get is a ton of stuff relating to Intel CPU's, chip sets, and compilers. Nothing relating to AMD.
    Anyone know what this setting actually does on AMD setups?
    (Not sure if this is the correct place for this. If not please move it.)
  2. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    well, this thread is now the top result for the google search 'amd core balancing'. lol
  3. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    At the risk of sounding obvious, does it not shuffle threads around so that each core is doing roughlt the same amount of work?
    Rather than have 1 core at 100% doing four things it jiggles stuff round so that each core is doing one thread.
  4. Aragon Speed
    12 Jan 2009
    No idea, that's why I am asking.
    That would be one logical idea, but I haven't seen much in the computer world that is logical when it comes to naming things. XD
  5. harryy
    harryy What's a Dremel?
    13 May 2010
    re:Motherboards Core balancing and AMD
    Hello,
    I think you will definitely find it on google try to find it with motherboard. I will also try to find some solution for it.
  6. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    I think ShakeyJake is right - my quad core usually has all cores running at about the same level and temp. Could be wrong though...
  7. bulldogjeff
    2 Mar 2010
    You're all pretty much on the right lines. It's in it's most basic form it's thread allocation, where windows will decide which thread to allocate to what core, Dependant on it's load. By messing about with the core balancing you can make 1 core do all the work or direct certain apps to a particular core and nothing else. As an example I could allocate 1 core to do nothing else but my virus scans and leave the rest for everything else.
    Now before you all go getting to excited as to what you could do with core allocation I would say don't touch it, windows just happens to be very good at sorting it all out for us.
    If you did really want to use core balancing , it would mainly be for servers where you would need certain applications to take priority over others when the system is under heavy traffic loads and these would then be cued and when resources become available they would then be dealt with in normal operation mode.
    So in answer to the original question, don't worry about what it does.....lol
