Build Advice Core i 7 build advice
Discussion in 'Hardware' started by brave758, 20 Apr 2009.
  1. brave758
    brave758 Minimodder
    16 Apr 2009
    Hi all,
    my first post here and i'm after a little build advice.
    I'm upgrading my current PC spec's
    P5E3 premium wifi
    Gskill 1600 4gig
    Q9650 Fuzion WB
    PA 120.3 Rad
    2 x HD4870 crossfire
    x-fi
    Enermax Galaxy 1000w
    Lian Li G70 EP-UK
    I'm thinking of upgrading to a Corei7 and have decided on 920 d0 cpu but a torn between two mobos the EVGA x58 or the dfi ut x58-t3eh8. But i still haven't decided on the ram yet.
    Thanks
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    There will not be much difference between a 920 and your current Q9650. At least not enough to justify the price.
  3. Guest-23315
    Guest-23315 Guest
    +1
  4. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Unless the OP is doing alot of multimedia work, programs that can take advantage of the I7's hyper-threading.
  5. trig
    trig god's little mistake
    10 Aug 2006
    performance increase no where near worth the cost of the upgrade. having said that, dfi if you like to oc and meddle, gigabyte or asus if you don't.
  6. brave758
    brave758 Minimodder
    16 Apr 2009
    Hey and thanks for the advice, dam i though i would of seen a bit boost going to a core i7.
    I'm not currently overclocking the q9650 its not a great vid (1.300) and ive been having some funny but easily fixed issues with it (C1E and speed step ramdom throttling under load when not overclocked) but i know ill get 3.6 if not 3.8 out of it (cooling with a fuzion and PA 120.3).
