Motherboards Core unlocking
Discussion in 'Hardware' started by andrew8200m, 2 Aug 2009.
  1. andrew8200m
    andrew8200m Modder
    4 May 2009
    Does anyone here know which motherboards unlock the cores on the x2 550 and the x3 720??
    Andy
  2. Guest-16
    Guest-16 Guest
    EDIT: I should read the question: Asrock, Gigabyte and Asus.
    It's not a guaranteed exercise btw.
  3. andrew8200m
    andrew8200m Modder
    4 May 2009
    I know its not guaranteed, I figured I may as well try my luck at unlocking either a 550 or a 720.
    Im building a computer for my brothers birthday and require some semi decent internals. It cant cost the earth as I have been made redundant so I figured instead of pushing the boat out with either an e8400 or a q8300 (as I cannot seem to find a q6600 anywhere) I would go AMD and try to either get a 550 unlocked or the 720. The 550 isnt much slower than the e8400 when it comes to games so I figured this would probably be the better choice.
    I have recently won an A7DA-s 3.0 and have this with an athlon 2 240 but due to how slow this is due to poor overclocking performance on the MB and the fact 2gb of ddr3 were on par in price with 4gb of pc6400 I thought I would sell them and opt for a phenom 2 (550 or 720) and a motherboard to match that has the potential to unlock any extra performance via either superior overclocking features or core unlocking or a mixture of both.
    Andy
  4. andrew8200m
    andrew8200m Modder
    4 May 2009
    Anyone?
    Andy
  5. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Why not go for the E7400? Its about £90 now, and as i can prove, will get to 4Ghz easily.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Why do you need to unlock cores? The 550 will eat the E7400 with the right chipset anyway, save yourself some money and effort overclock the 550, if your set on a quad core the 9950 can be picked up for under £100 now... and an AM2+ gaming drivetrain (RAM+Mobo+CPU) would cost under £200 in total for a decent set up add on a £100 HD4870 and bang your in win street... AMD For The Win!
  7. andrew8200m
    andrew8200m Modder
    4 May 2009
    Im working on a budget, a 550 or a 720 overclock beautifully and out perform most dual core core 2 duos. So I will be settling on one of these chips however you seem to be missing my point. I want a board that could "potentially" unlock cores so I get something for nothing as it were. If the board doesnt unlock the cores then its no biggie but having the facility to do so is what I require just incase I have a lucky chip.
    Andy
  8. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Ahh ok, my bad
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  10. andrew8200m
    andrew8200m Modder
    4 May 2009
    No worries, response wasnt supposed to sound sarky lol. I just havnt been too clear I suppose. Thanks for the help though
    Andy
  11. Guest-16
    Guest-16 Guest
    EDITED my earlier post: Asrock, Asus and Gigabyte do on some recent models. They require ACC (SB710/SB750 southbridge) and a compatible BIOS.
  12. andrew8200m
    andrew8200m Modder
    4 May 2009
    Thanks for your help there guys :)
    Andy
  13. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    A first gen Phenom, why? anyway, the 905E is only £30 more and has a lower power draw.
