Other Corel Paint Shop Pro X Free
Discussion in 'Software' started by jbloggs, 17 Jul 2009.
  1. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    You can get it Here
    To remove nag screen (on exit) do the following:
    1. After installing, open the following file in Notepad:
    C:\Program Files\Corel\Corel Paint Shop Pro X\PCUUI\Container.htm
    2. Erase all the text, replace it with the following code:
    <script type="text/javascript">
    location="pcucmd://Cancel?confirm=no";
    </script>
    Save the file
    ________
    YOSELIN
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Nice find but what's the catch,I just downloaded it, nothings for free :)
  3. GoodBytes
    20 Jan 2007
    I am happy with Jascs Soft Paint Shop Pro 7. Works perfectly under 2000, XP, Vista, Win7.. and I am not even at a point to run it in any compatibility mode. The only down side is the file associate doesn't work.. but I don't care. It opens just as fast as Photogalary in Windows :)
  4. jbloggs
    12 Sep 2007
    There is no catch and it is completely above board, I even posted the "fix" to remove the "nag" on exit...
    ________
    Glass pipe
  5. haddow64
    haddow64 What's a Dremel?
    24 May 2009
    Excellent, I prefer Paint Shop over Photoshop as I have no need for so many features. Plus photoshop is easier to use.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I've been using PSP 7 for ages too and always been very happy with it.
    Just hoping this one allows you to crop an image to specific dimensions, ie so I can cut a section out of an image that will allow me to print it at 6x4.
    Thanks for the find Jbloggs.
  7. Loom
    Loom What's a Dremel?
    10 Aug 2008
    Reminds me of a younger self but nowadays I prefer the easier option - unless you actually meant PSP is easier to use!
  8. haddow64
    24 May 2009
    eh *facepalm* yes i meant paintshop. I dont think anyone can believe that its easy to use photoshop.
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    I was once a happy user of paintshop 6,7,8, and 9 then a photoshop CS2 disc appeared on my desk one day, and well i've been using that since.
    I did pirate CS3 so i could trial run it with all the features, but i just couldn't see the point with it and ended up going back to CS2.
    Paintshop pro X does look interesting.
  10. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I used to use PSP but since finding Paint.net I have had no need to go back to it. I didn't even bother to reinstall PSP after my last rebuild, ~20 months ago :)
  11. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    I am one of the people that way back when got along better with photoshop, and since has stuck with it... CS2, CS3 and now CS4... all original...
  12. jbloggs
    12 Sep 2007
    This offer seems to have now "expired"!
    ________
    LIVE SEX
