Windows Corrupt Access DB
Discussion in 'Software' started by aryehsteiner, 21 Jul 2015.
  1. aryehsteiner
    aryehsteiner What's a Dremel?
    20 Jul 2015
    Access 2003 database. Unable to open - error message "database engine could
    not find object MSysDb".
    Can not JetComp it; can not import tables into a new db; can not open in
    Access 2007; can not compact & repair.
  2. phuzz
    phuzz This is a title
    28 May 2004
    Yesterday's backup?
  3. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Previous versions?
  4. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    I'd say search for a similar sized file with a different name (like ZXCFGREWJW.tmp, it'll look quite arbitrary) in the same directory (make sure hidden files are shown) and temp dir, try renaming any such found file to be an accdb or mdb file and attempt to open that.
    MSysDB, I think, contains the metadata for all the tables held in the file. without that data, you can't reasonably interrogate it at all. You're then into opening the file in pure binary. Good luck with that, especially if it's encrypted.
  5. jensonwright
    jensonwright What's a Dremel?
    27 Jul 2015
    Try this sequence in order below or as an additional resources for restoring .mdb file see and learn following topics, and in case your corruption is severe, one more solution must assist you Access Repair Toolbox
    The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
    1. Do not open Access database must closed
    2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
    3. Close the .mdb file related to .ldb file before you delete the .ldb file.
    4. Then Run the Compact and Repair tool
  6. Leiton
    Leiton What's a Dremel?
    23 Feb 2017
    Hello, I need recover an Access database now but this software does not work. Is there other access database repair software that works?
