Motors Corsa B clutch cable snapped *updated*
Discussion in 'General' started by Margo Baggins, 23 Oct 2014.
  1. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Hello,
    currently I have a temporary fix from the AA man sorted for me at the side of the road, which means the clutch is about as high as my chin when i'm driving, and is obviously only temporary fix.
    I think it looks like an easy job but i've never done anything "car" before, but i'm fairly apt with my hands.
    I just don't really want to take it to the garage when it's a 20 quid part and they'll probably fleece me.
    I'm not stupid for wanting to do this myself out in the street am I?
    Thoughts please :)
  2. jinq-sea
    15 Oct 2012
    No - I would imagine that it'll be fairly easy, but I've never done one on a Corsa. Get yourself a Haynes workshop manual pronto (and you may see pictures of one of my friends' hands in it) and suss out what it will involve :thumb:
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Last time I did one is was much like changing a brake cable on a bike.
    Really easy.
  4. jinq-sea
    15 Oct 2012
    ...unless it's like a RHD K plate Clio, which retains the same layout as the LHD Clio for the clutch cable and therefore induces all manner of rude words!
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    ...apart from the fact that the OP has a Corsa not a Clio ;)
    You'd be better off if you could get the car off the street so you won't have to worry about passing traffic running over your feet!
    It should be a fairly easy job, although you may want another person on hand to press clutch pedals, pass tea and so on.
  6. jinq-sea
    15 Oct 2012
    Err, yeah - I know that! Hence why I said it should be fairly easy... :facepalm:
  7. Rhydian
    Rhydian What's a Dremel?
    13 Nov 2010
    It's a tool less job most of the time, just look where your current cable is, then do the exact same thing (without snapping it this time!)
  8. Margo Baggins
    28 May 2010
    Cool, I will order parts tomorow, and give it a crack next weekend!
  9. Refugee
    Refugee What's a Dremel?
    25 Aug 2014
    Have a decent pair of pliers and mole grips handy + a friend to help out with the replacement, it's not a difficult job maybe an hours works but it fiddly and an extra pair of hands will come in handy(pun not intended).
    It can be done on the side of the road but you need the drivers door open to get to the clutch cable, unless you are a very small person who can kneel down in the drivers foot well.
  10. Margo Baggins
    28 May 2010
    The saga continues - so I now have the part, but it appears to be missing a part, at least I think it is.
    On the end of hte cable is a threaded rod, my understanding is that this screws through a sort of block that sits on the other side of the clutch lever, in order to anchor the cable and allow you to adjust the clutch. The new cable I've bought doesn't have this on the end - and, I don't have one anymore as when my clutch cable snapped I guess I lost this to the road, as I didn't have the threaded rod nor this little termination block. Just a frayed cable poking out of the outer.
    should that of come with the cable? I think it should have. And if it shouldn't have - what is this part called? Does anyone know?
  11. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Could it be Number 14 on this diagram?
    Little pricey, clicky
    *EDIT*
    Or is this the cable, with the threaded rod and adjuster?
    That one, that first link possibly another, and I've seen one on ebay that just has a ball end.
    Seems to be a bunch of different cables for this model.
  12. Margo Baggins
    28 May 2010
    Thanks! I'm sure no 14 on that diagram would work but it looks way too posh.
    I think this is potentially it http://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL_CLUTCH_PEDAL_ADJUSTER_NUT_-_90065408.html
    but it doesn't specifically say, but it looks exactly like the part I need.
  13. Margo Baggins
    28 May 2010
    Took 25 minutes, if that. :)
  14. Shirty
    18 Apr 1982
    I'd expect nothing less from a man with such deft hands :D
  15. Margo Baggins
    28 May 2010
    The main struggle I had was getting my manly forearms into the tight spaces, and now I have scratched up forearms to testify!
    That's the first "car" thing I've done, broken my cherry.
  16. creative
    creative 500rwhp
    23 May 2014
    if you dont draw blood whilst working on a car... then your not doing it correctly! That and learning the mechanics language... Basically swearing at it until it fits, whilst drawing blood... :D
  17. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    And Creative's comment is now my sig..
    I know the pain of drawing blood while working on a car..
