Video Corsair 1000D Mega-Build Update 4: Machining the Rear Panel
Discussion in 'Article Discussion' started by bit-tech, 17 Aug 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Lovely. I was expecting a 20 minute montage of you removing the plate from the machine. :D
    For small metal parts I've switched to -wait for it- window glazing/caulk on mdf sacrifice. :lol: The small bits couldn't dissipate heat buildup and were melting the tape. You have to soak the MDF in water to remove the parts.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Ooh I’ve not heard that one before, may give that a try at some point, cheers for the tip my dude.
  4. GtrainRx7
    GtrainRx7 What's a Dremel?
    18 Aug 2014
    I love these buildup/teardown etc videos. But I can't watch them.
    Something on the screen distracts me :-/ I just can't help but stop and stare.
    Sorry. I am sure you put a lot of effort into it.
  5. The_Crapman
    5 Dec 2011
    So beautiful. So very beautiful. :baby::naughty:
  6. Cheapskate
    13 May 2007
    +2 'stache comments. ^
    The_Crapman likes this.
  7. SheDevil
    SheDevil What's a Dremel?
    29 Aug 2018
    any there have the DXF files for i really like the custom plates hope somebody have the files
  8. SheDevil
    29 Aug 2018
    amazing drawing any there have the files for it for i really like the idee about it and working on my own custom made corsair 1000D mega build
  9. Cheapskate
    13 May 2007
    If Alex didn't draw it himself, the case model is likely protected by a non-disclosure contract. You can't just give away a CAD file in an industry full of knock-off manufacturers.
    You might contact Alex about making some plates for you, but he probably isn't going to give his drawings away.
  10. SheDevil
    29 Aug 2018
    it's not meant to be drawing I'm out to measure where the screws are set for drawing it in solidworks that I know best to draw programs
    because I'm waiting for my corsair 1000D when it's in stock in my country so just want to draw it while I'm waiting for it
  11. Kurt Jørgen Oldervik
    Kurt Jørgen Oldervik What's a Dremel?
    14 Apr 2019
    I would really love to get the file or the measurements. I made a order for a 1000D myself and would like to get a plate made. Not the same you made but maybe having 2 vertical gpu's and some other fun parts. I dont want to cut my chassi into pieces before i have the new plate in hand. Just the outside measurements would do really. With the corner cuts.
Tags: Add Tags
