Video Corsair 1000D Mega-Build Update 5: Integrating Reservoirs into a Distro Plate!
Discussion in 'Article Discussion' started by bit-tech, 24 Aug 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Using the mating plate to zero a part you need to mill the back of... I saw that. That's a dirty trick, and it's brilliant.
  3. loftie
    loftie Multimodder
    14 Feb 2009
    Good video, music/voice audio levels seem bang on since the last one I watched. Pretty hypnotic to watch it all, and coconut shavings sprung to mind when Johnny 0.5 went to work.
    Edit: Still can't fullscreen the video, is this just me and Opera being special?
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    Don't show Charlie Sheen this video.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Doesn't work for me either, option is greyed out in the embedded video, but if I go to youtube it works fine there (Opera 54).
  6. RedFlames
    23 Apr 2009
    It's being 'special' in Firefox [62b20] and Edge [44] too
  7. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Are you at Lan then buddy?
    J.
  8. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I am genuinely impressed that you are already to the point where you are thread milling. What has it been, a few months since you got the router? I still dread thread milling when I have to do it.
  9. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Nice work.
    Are the plastic shaving that hard to control or was your vacuum not turned on?
  10. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Looking into this :thumb:
  11. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Threadmilling was just waaaaaay too good an opportunity to pass up on haha. I've actually used it for every block I've made on the machine so far, so starting in April or so. Parts of it definitely give me the heebie jeebies though, have to trust that I've not forgotten any options in CAM or else CRUNCH. That threadmill cutter is ridiculous though, being able to cut and thread the hole in one pass save so much time on larger jobs.
    Main issue atm is that the bristles aren't quite long enough to catch all the chips for the longer endmills. I could try making a floating dust boot, but that feels fairly far down the line currently. It's still significantly better with the shoe than without though so that's good at least.
Tags: Add Tags
