Case Mod - In Progress Corsair 250D Simple mod , by iD2
Discussion in 'Project Logs' started by iD2, 24 Oct 2016.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Hello, Today i will show my 1 day project by moding Corsair 250D.
    Project :: Corsair 250D rotate cases mod
    Project time :: 1 Day
    Project Description ::
    Change Corsair 250D by rotate it and using DVD bay for cover the mess wire and use it for mount SSD or Reserviors , This cases mod with not drill any hole for convert DVD bay , except the top cover that will cut for attach new acrylic panel.
    New parts lists ::
    - 2mm Acrylic 28.5x25cm
    - Double-sided adhesive tape
    - Aluminum 1/2" , length 9cm for mount DVD bay
    - 4pcs rubber feet
    PS. It will really good if the feet of Corsair 205D font panel itself can disassembly like rear feet , then this will be perfect rotate cases.
    Finished mod ::
    Start ::
    Start assembly ::
