Modding Corsair 460X Build for BoMenzzz: Part 2
Discussion in 'Article Discussion' started by bit-tech reviews, 21 Mar 2017.
  1. bit-tech reviews
    bit-tech reviews Administrator Administrator
    10 Mar 2017
  2. Impatience
    Impatience Minimodder
    6 Apr 2014
    Really enjoying this little series! :thumb: With the rear panel, did you measure where the motherboard standoffs are and cut out holes, or does the panel nor go the full way across the side of the case? Just asking as wanting to do something similar for my 350D. (as it's got a giant hole in the rear wall where the ODD/HDD cages are!)
  3. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    I made it so that the panel just touched the standoffs, there is no need to go any further really. If you did want to though, just use a 4mm drill bit and you would get a rather nice fit for them :)
Tags: Add Tags
