corsair 620w or 750w psu
Discussion in 'Hardware' started by heir flick, 11 Jan 2008.
  1. heir flick
    heir flick Active Member
    2 Feb 2007
    im about to put together my new parts
    q6600
    asus p5e
    Geil Black Dragon PC2-8500 1066Mhz 2GB
    samsung spinpoint 500gb
    8800gts 640mb (keeping this and waiting for the next gen card)
    Corsair HX620 620 Watt PSU or Corsair TX750
    will the 620w psu be ok or should i dig a bit deeper and get the w750
  2. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    620 would be fine I believe. Even the 550 (or 520) would probably be suffice.
  3. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    You're probably not even hitting 300w of power right there. Are you OCing at all? If so, maybe a little over 300w. You're perfectly fine with the 620HX. I'm running a beefier rig than this on the same PSU. Plus you get the capability of modular, unlike the other unit....assuming you see that as a plus.
  4. Guest-23315
    Guest-23315 Guest
    620HX. You'll be a happy bunny.
    Otherwise, I'd go for a PCP&C Silencer 750.
  5. lamboman
    lamboman New Member
    25 Jul 2006
    None of them. HX520 will be fine.
  6. heir flick
    2 Feb 2007
    thanks i was hoping not to spend any more than needed
  7. wyx087
    15 Aug 2007
    Hx620w hands down.
    that system is easy for 620w, even 520w should be able to handle a quad core and GTX.
  8. fathom17
    fathom17 New Member
    20 Sep 2005
    I've just been running over that system on a HX620. Its very happy and cool. :)
  9. heir flick
    2 Feb 2007
    620 it is, on order picking up tomorrow
