Case Mod - In Progress Corsair 760t Case Modify
Discussion in 'Project Logs' started by pcmatters, 25 Oct 2015.
  1. pcmatters
    pcmatters What's a Dremel?
    18 Aug 2015
    Hi once again I'm Edoy from Davao City Philippines this is my Project now guys a 760T Corsair Case. Theme weather paint black red. Semi Attack on Titan Concept, Hopefully you will like it and feel free to ask just comment your insights. Thanks
    1. I make a hole front of the case so it can fit 3fans in this this hole i can easily put and detach 3fans.
    a. [​IMG]
    2. Cutting the design of the holder of fans
    a. [​IMG]
    b. [​IMG]
    c. [​IMG]
    2. Making exhaust circles for the fans in front
    a. [​IMG]
    b. [​IMG]
    c. [​IMG]
    d. [​IMG]
    e. [​IMG]
    f. [​IMG]
    g. [​IMG]
    3. Preview of the looks front of the case
    a. [​IMG]
    b. [​IMG]
    c. [​IMG]
    4. Sanding and Primer Paint
    a. [​IMG]
    b. [​IMG]
    c. [​IMG]
    d. [​IMG]
    e. [​IMG]
    f. [​IMG]
    that's for to now i will update soon for futher improvement of the mod, Thanks guys for watching and keep following my works. :rock: :lol: :baby:
    Continuing its been a long time no update this post internet here in Philippines quite sucks!
    I decided to change the design of its psu cover.. so here it goes
    side pannel design:
    cable cover
    Primer Paint of the pieces:
    http://i.imgur.com/NOXgOOE.jpg[/IMG...rb.jpg[/IMG] thats for all now! Thanks :)
  2. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    Looking amazing so far, very interested to see the final look.
  3. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    Great acrylic work.
  4. Icelander
    Icelander Minimodder
    3 Mar 2015
    awesome so far
  5. pcmatters
    18 Aug 2015
    Thanks AlphaAngel :)
    Hopefully i will do the weather paint on this perfectly and also side panels :) :D
  6. pcmatters
    18 Aug 2015
    Thanks Marquee
    hopefully i will finish this good. :) :):D
  7. pcmatters
    18 Aug 2015
    Thanks Man IceLander
    keep following :) :D
  8. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That is looking good so far.
  9. pcmatters
    18 Aug 2015
    Thanks Tim :)
  10. BLAMM0
    BLAMM0 What's a Dremel?
    28 Jul 2014
    Totally awesome, keep it up.
  11. pcmatters
    18 Aug 2015
    Thanks Man
