Cases Corsair 800D case
Discussion in 'Hardware' started by happyhammer7, 28 Jun 2011.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    I am looking at water-cooling my rig, which is currently housed by a corsair 650D. I know this case is somewhat restrictive in terms of W/C potential. I do love this case so will use it for my server build.
    Anyway, I cannot afford a water-cooling setup until a couple of months but was wondering would the air cooling for the 800D be sufficient short term?
    I will need to upgrade the fans but I wanted to upgrade them so they will be useable for when I do W/C.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I've seen a couple of people use it for air, but even they say it's not great...
    Consider the Elysium...?
  3. happyhammer7
    19 Oct 2009
    Funny you should say that, was just watching this
    http://www.youtube.com/watch?v=ICPvEjUDgz0
    Cannot believe this case is £140.
  4. Bloody_Pete
    11 Aug 2008
    I've seen it for £125 on Eclipse computers...
    P.S. I have one sitting across the room from me, there are pics in my thread of it... It's a really great case!
  5. Drekz
    Drekz What's a Dremel?
    26 Jun 2011
    The Elysium completes the full-tower package all at a very attractive price tag. Those grommets for cable management are also amazing, something that I thought only Corsair offered :) The side panel for additional fan mounting options is also pretty nice and you don't get anything like that on the 800D.
  6. happyhammer7
    19 Oct 2009
    Never brought from them before, are they any good?
  7. jamsand
    jamsand Minimodder
    21 May 2011
    ^ only ever had one order from them so can't say much but did exactly as they said with no hassle. also the Elysium looks amazing for watercooling specially a that price xigmatek seem to be owning the chassis market atm first with Utgard now Elysium.
  8. Bloody_Pete
    11 Aug 2008
    I haven't ordered from them for years, never had a problem when I did though :)
  9. Jipa
    5 Feb 2004
    And when talking about a case, they would really have to BLOW to screw something up :D It's not like you'll have to deal with warranty, anyway.
  10. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I run an air cooled 800D, and the posts above are correct. With stock fans and no extra fans installed, the airflow is less than acceptable; however, if you upgrade the fans and install fans in the 3x roof mounts, then yes, it's OK. Not great by any stretch but OK.
    It doesn't affect me too much because my office is AC'd at 18 degrees 24/7 so I can live with higher Delta temps.
    It also depends what hardware you're going to put in. I'm running X58 S1366 gear which is way hotter than Sandybridge, and you could get away with a more compact watercooling case for Sandy and pocket a lot of change too.
  11. happyhammer7
    19 Oct 2009
    I am running the same, hence my initial concern. You really could bake an egg on this kit.
  12. happyhammer7
    19 Oct 2009
    Can you acutally mount an SSD in this case?
  13. Bloody_Pete
    11 Aug 2008
    Only with adapters...
  14. samkiller42
    25 Apr 2006
    The Corsair 700/800d are both aimed at Watercoolers, which is where it excels.
    I did install 3 Gentle Typhoon 1800rpm fans to the roof, which are controlled at 50%, and my CPU temp is 46c under a Corsair H50. My GTX580 is currently at 46c too.
    Sam
