Case Mod - In Progress Corsair 800Dutch MbK
Discussion in 'Project Logs' started by kier, 29 Jul 2015.
  1. kier
    kier -----------------
    1 Mar 2011
    Sponsored by:
    We are back!!!
    Didnt post much buildlogs on the forums these last months, because of some personal stuff.
    But I did some builds for events... And also started a nice project with two golden oldies.
    These are... two recycle cases: The Corsair 800D and 750D.
    Both dismantled.
    After this, used the two fronts and one top and bottom.
    And I have modified one back so that the mobo tray exactly is in the middle
    En de bedoeling is dat aan beide kanten een 480 radiator komt te zitten
    Changed the other top, for the external cables to disappear.
    With help from mini Kier
    And I've made an aluminum backcover and bend a midcover
    More soon!!
  2. kier
    1 Mar 2011
    UPDATE: Corsair 800Dutch MbK
    Sponsored by:
    Measured and cut a orange acrylic plate to fit one of the midplate
    I have covered the bottom of the plate with white vinyl ... more on this later ;)
    Bend a aluminum plate to get a separation
    On top of this also an orange acrylic plate
    On this also a layer of white vinyl.
    And then on the white a layer black vinyl.
    Bottom now looks like this
    When placing a LED strip beneath this the dispersion of light is nice and smooth and because of the white vinyl a better light distribution.
    Now the first products of a great sponsor .... GIGABYTE!!!
    For this build they provided me some Gigabyte TITAN X GPUs
    And a great motherboard: the Gigabyte GA-X99-SOC Force
    Putting this together, you'll get this:
    Perfect for this build :)
    I also have cut a pair of orange plates for the second midplate.
    Looking good :)
    Back to the top ... I have cut some small orange plates orange acrylic for the bended aluminum and made one edge, which will be placed like this.
    What looks like this from the front.
    Once en-lighted this will give a nice glow.
    Until the next update ;)
  3. montymole
    montymole Rigid Tubist
    24 May 2010
    Very nice work great way to recycle some old cases :)
  4. kier
    1 Mar 2011
    Thanks Mr. Montymole ;)
    Sponsored by:
    For this build I'm going to use setup in the reservoirs and pumps ... 2 pumps with BP kits, tops and reservoirs on either side of the motherboard. More about this later.
    Placed two nice grills onto the radiators
    Covered the midplate with orange acrylic
    And placed a a layer of white and black vinyl onto the grills.
    Also made the midplate black
    Used a stip of acrylic for the sides of the rads and also made black.
    For this build Corsair sended me two beautiful Dominator® Platinum Series 16GB (4 x 4GB) DDR4 DRAM 3400MHz C16 Memory Kits
    Perfect for this motherboard!!!
    And mounted some LEDs behind the grills and under the midplate
    Finally I will place 4 SSDs at the back of the case, got some nice space left for this.
    On both sides 2x SSD. For now red ones for measurments, but there will be other ones.
    To be continued!
  5. kier
    1 Mar 2011
    Sponsored by:
    Time for a new update! I used some other cards to show you how I'm going to make the setup in terms of the water cooling. All tubes going up.
    The idea is to connect everything in the upper compartment.
    Also did some brainstorming for the sidepanels. For this I used an acrylic orange plate with a black plate on top off this with fanholes
    On the sides behind the orange acrylic illuminated with RGB LED strips
    In the dark
    Also in the Corsair package, beautiful Air Series AF120 LED White Quiet Edition High Airflow 120mm Fans
    Which fit perfectly in this build. Therefore exchanged them with the old ones.
    Internally, I also added some nice things. For this I called my good friend Pascal with his CNC.
    Much easier then sawing ;)
    Again a plate as the sides with small slots.
    and for eye catcher the same plate with a circle in the middle + inlay with my "MadebyKier" logo.
    This is actually 6mm transparent acrylic with this a layer of white and then black vinyl, again for better light distribution.
    More soon ;)
  6. storm-83
    storm-83 Minimodder
    7 Nov 2014
    looking good :thumb:
  7. kier
    1 Mar 2011
    Thanks :thumb:
  8. Icelander
    Icelander Minimodder
    3 Mar 2015
    awesome Kier
  9. kier
    1 Mar 2011
    Thank you!
  10. Cheapskate
    13 May 2007
    I knew you were up to something when you covered the fan guards. That is an awesome effect.:rock: The whole thing looks so d*mn good! Like the orange bleeding into the white lights too, even if it's an accident. It just mixes nicely.
    Also, More magic by Paslis on the sly.:D
  11. kier
    1 Mar 2011
    Thanks mate :rock: But not the "Paslis" Pascal ;)
  12. Cheapskate
    13 May 2007
    Noobs can't find his threads without his user name. As a devout follower, I feel I need to spread his shiny stainless teachings.:D
  13. kier
    1 Mar 2011
    In my post? lol
  14. Cheapskate
    13 May 2007
    If they are here, they figured out you are awesome.;)
    -Or are you saying there's another Pascal? I hope I'm not blurring 2 modder/fabricators into one.:worried:
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looks awesome. :clap:
  16. kier
    1 Mar 2011
    Thanks!
    Yes, that's what I'm saying.... Got me my own Pascal :lol:
    Thanks Waynio :rock:
  17. kier
    1 Mar 2011
    Sponsored by:
    Also continuing this build after a little "break"
    I have some beautiful products Bitspower chosen something perfect comes into its own in this build.
    Meaning the Bitspower CPU Block Summit EF True Black
    And with two beautiful Bitspower VG-NGTXTITANX BLACK ACRYLIC for the GIGABYTE TITAN X GPUs
    Big help from mini kier
    And the waterblocks for GPUs
    Really love the backplate
    Time to place some more stuff like the reservoir combo's: the Bitspower Water Tank Z-Multi 250 V2
    And some Bitspower Carbon Black Enhance Rotary G1/4" 90-Degree Multi-Link Adapter
    Also G1/4" Carbon Black IG1/4" Extender-50MM en G1/4" Carbon Black IG1/4" Extender-25MM to extend the CPU in/ outlet
    Beneath the res combo's 2x a D5/MCP655 MOD KIT V2 for the D5 pumps.
    And two times a Bitspower D5 MOD TOP
    Marking the brackets
    And everything put together.... You'll get this :)
    Time for some big cutting :) Holes for the tubing and stuff
    Piece of orange acryl marked and sawn.
    Holes for the riged tubing
    And placed some black vinyl on it
    After this made another cover and pasted some more vinyl :
    But, more about this later ;)
  18. Vault-Tec
    30 Aug 2015
    Glad it's back on track. Such an awesome build :)
  19. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Really enjoyed the build log so far...great stuff.
  20. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    You sir, are the reason i'm interested in PC modding :thumb:
