Cooling Corsair announces H100i and H80i
Discussion in 'Hardware' started by GeorgeK, 5 Nov 2012.
  1. GeorgeK
    18 Sep 2010
    Recently announced here. Would seem like they've taken one of the awesome features of Antec's Kuhler range (USB connectivity) and implemented it in the redesigned versions. Also they're apparently using better cold plates, tubing and fans based on their SP range of fans.
    Might have to get me a H100i as I've been looking at them but the fans and the controllability have been putting me off - good job I've got a little bonus coming my way :thumb:
    Piccys:
    Peoples' thoughts?
  2. Rrruby
    Rrruby What's a Dremel?
    16 May 2012
    IMO they definitely look better than the current H series, but I guess it matters less what they look like and how they perform. Have Antec released a new range of sealed coolers yet?
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I want and well get
  4. Strudul
    Strudul ~
    31 May 2010
    The fans look classy.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    No point if they're still using CoolIT as the OEM
    Fans look great though
  6. GeorgeK
    18 Sep 2010
    Why's that? The fans do look awesome :D
  7. legoman
    legoman breaker of things
    28 Feb 2010
    Looks good, also looks like they have gone with their own custom fan connectors which is never a good sign. Custom fan profiles will only work with those fans id imagine.
  8. GeorgeK
    18 Sep 2010
    Didn't twig that when I first looked... I just thought "those fan connectors look odd... oh well..." :duh:
    That's a bit of a let-down then since if a fan was faulty you'd have to RMA it and wait for a replacement rather than just swapping out the faulty fan - also if they turn out to be loud / rubbish then you're stuck with them...
  9. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Don't fret, the fans use the standard connector and Corsair provides an adapter:
    (adapter cable is next to the USB cable)
    Fan connections:
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    Hopefully they've fixed the issue with the rattling H80 pumps!
  11. Kovoet
    26 Aug 2009
    Mine didn't even work even though brand new. But never had a problem with the h50 or the h100
    Sent from my Nexus 7 using Tapatalk 2
  12. megadriveguy
    megadriveguy Minimodder
    19 May 2010
  13. GeorgeK
    18 Sep 2010
    Drools... Just need to find a UK release date now :D
    Edit: Scan reports that they are 'due today' :D:D:D
  14. Kovoet
    26 Aug 2009
    Think I need to place an order
  15. GeorgeK
    18 Sep 2010
    Me too - will have a look on their site tomorrow :thumb:
  16. Kovoet
    26 Aug 2009
    You can pre-order the H80 at scan but not the H100. But you can at overclockers for 92 quid and 91 at yoyotech
  17. Baz
    Baz I work for Corsair
    13 Jan 2005
    Needless to say, we're banging down Corsair's door for these to review. Corsair Link software has come a long way, and us really quite impressive now,
  18. GeorgeK
    18 Sep 2010
    I was intrigued by the Corsair Link software when I first heard it announced, but to have to buy a separate controller ('Commander') for $70 was a bit ridiculous even if it did come with some temperature sensors thrown in...
    Edit: Still no sign of these being in stock anywhere... :(
  19. GeorgeK
    18 Sep 2010
  20. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Order a H100 the day before this was in the shops.. Ah well. :) I like the look of the old one anyway. The tubes on this one look like the inside of a car. :/
