Hi all Who has a Corsair AX850 PSU? Does anyone of you know what connector is which? what each socket connects to?
18pin+10pin = 24pin 6pin=SATA/Molex 12pin= PCI-E 8pin=8pin EPS12V Also worth pointing out that it's impossible to plug them in wrong
Oh, it's for the motherboard sorry. It can split into two 4s if needed. Here's a pic to explain further Blue=Molex/SATA connectors Green=PCI-E/8pin motherboard connector Yellow=24 pin motherboard connector
I must say that's a substantial oversight on Corsair's part. To experienced system builders PSUs might be much of a muchness but even I'd be a bit peeved that the connectors are unlabelled anywhere on the PSU or in the manual
I know this sounds like a noob question, but the two connectors in green which are stated as 8pin have 12pins in the socket, I assume when connecting cables to that socket it will not use all those pins?
This is what you need to plug into your GPU: Then the other end goes into the relevant green outlined slot in Noiz's image above.
Apart from IDE and floppy drive ribbon cables, which you can plug in the wrong way round. With luck though none of us will have to deal with too many of these again.
What GoodBytes said. There is no labeling needed, because you simply can't plug them in wrong way without excessive force. Note how some pins have square holes, while others have two square corners filled. Combinations of these makes the connectors impossible to mix up (good luck mixing up the 6, 8, 10, 12 and 16 pin connectors).
