Case Mod - In Progress Corsair Carbide MbK
Discussion in 'Project Logs' started by kier, 26 Aug 2013.
  1. kier
    kier -----------------
    1 Mar 2011
    Thanks y'all
    Update!!!
    As promised the sequel:
    First a filling vid:
    And the pictures of the filled Corsair Carbide
    After letting it run for a while, it seems to appears to have no leakage ;)
    My good CNC mate Pascal (thanks man) had a nice RGB controller which can dim the RGB LEDs very nicely. This gives a very cool effect when spinning the fans. Also placed another RGB strip internally.
    Lights out!!!
    All colors of the rainbow available again:
    And cold white again
    Or a bit warmer
    Like I said, the dim function is quite fun to see
    full power:
    Dimmed:
    Also a movie of this nice effect :)
    Until the next update again my modding friends ;)
  2. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Beginning to think I should copyright this thing :lol:
  3. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Absolute beautiful build, love it Richard. :thumb::thumb:
  4. kier
    1 Mar 2011
    WOW....HEEEADSHOT! :jawdrop: :clap: much better then a :wallbash:
    Thanks Craig :thumb:
  5. KidMod-Southpaw
    28 Sep 2010
    Just wow...
  6. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Well god damn!
  7. blueviper11
    blueviper11 What's a Dremel?
    9 Sep 2010
    WOW....... I want one!!!!:rock::lol:
  8. faxiij
    faxiij Minimodder
    25 Jan 2011
    That looks brilliant. Love the idea and how it was carried out. Got you down already as a possible contender for MOTY 2k13 ;) Don't disappoint me kier! :D (well, as if you ever did.. ;) )
  9. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Wow! I tip my hat to you good sir. Very Clean, beautifully executed. Congrats, a build to be truly proud of.
    J.
  10. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    Awsome
    How much space is between the End of the mainboard and the case floor ?
    Would an Aquaero fit there ?
  11. kier
    1 Mar 2011
    Thanks HackJoe :clap:
    Thank you saxovtsmike, (without my custom midplate) there is about 6cm space and an Aquaero is 4cm so it will fit yes
  12. kier
    1 Mar 2011
    Update!!!
    The story continues ;) This time with a upgrade with beautiful products from Corsair
    Last week I received a great package with the products:
    First 4 pieces of RAMs, the great Dominator Platinum
    - 16GB Kit (4 x 4GB)
    - Speed Rating PC3-15000 (1866MHz)
    - SPD Speed 1333MHz
    - Tested Speed 1866Mhz
    - Tested Latency 9-10-9-27
    - SPD Latency 9-9-9-24
    Also with two sets of Light Bars
    Dominator Platinum Light Bar Upgrade kit
    The bars in two colors. will use the white ones in this build
    And all necessary parts
    Placed them...
    And tested them.
    Looks so much better then the previous RAMs.
    Also I've received some fast Corsair Neutron GTX SSDs (120GB SATA 3 6Gb/s)
    Max Random 4k Write - 84k IOPS
    Interface SATA - 6Gb/s
    DRAM Cache Memory - 128 MB
    Power Consumption (active) 4.6W Max
    Power Consumption (idle/standby/sleep) 0.6W Max
    S.M.A.R.T. Support
    Shock 1500 G
    MTBF 2,000,000 hours
    Also modded these by placing a window
    After some sawing and filing...
    The 3 windowed SSDs
    To place this I've cut a piece of aluminum ​​and bent
    Made slots in it ​​for SSD power and Sata + a hole for a fan controller
    Will be placed like this
    Made it black and installed everything
    Everything still visible with the windows side panel
    Because I had a different brand of PSU in it, Corsair had some questions about this and they decided to send me this nice Corsair PSU :)
    The Corsair AX860i
    Enough cables.
    Unboxing
    Always nice to get a PSU in a velvet pouch
    The PSU
    Fully Modular
    Power - 860 Watts
    80 Plus Platinum
    ATX Connector - 1
    EPS Connector - 2
    PCI-E Connector - 6
    4 Pin Peripheral Connector - 8
    SATA Connector - 12
    Floppy Connector - 2
    MTBF 100,000 hours
    Connections enough
    Also in a bag, just unfortunately not velvet ... The cables:
    And the Corsair Digital Link
    Placed it
    Cables "formed" a bit allready. This time I did not apply sleeve because the black wires looks very good as it is now.
    Expanded the cover of the SSDs slightly to get a better appearance, so created a window for the part with the pump.
    Placed 1 RGB strip above the SSDs
    And the other side with the black cables
    Tried to place everything as "clean" as possible and think it worked :)
    Now testing, and ... the final photo shoot.
  13. jeckulz
    18 Jan 2011
    I don't want my 540 now :(
    I want a swap
  14. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Those SSD's look amazing, got any disassembly pictures of those?!
  15. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    kier love those SSD's. How did you attach them to the case. Hope you don't mind me asking. Quite interested as I might try it on mine
  16. kier
    1 Mar 2011
    Thanks... the SSDs are attached with a piece off acrylic on the back with bolts. I will make some pictures for you
  17. Kovoet
    26 Aug 2009
    Thanks so much. Looks so much cleaner the way you have done it
  18. Asouter
    Asouter --------
    18 Jan 2012
    Like how clean the tubing is :thumb: quick question... I see you have fitted the light bar kits to your RAM, how much light do the kick out normally ?
  19. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    I absolutely love this build!! Looks fantastic man.
  20. Jezzafool
    Jezzafool What's a Dremel?
    2 Sep 2011
    Just Perfect. There I named it for you :D
