Hardware Corsair Carbide Series 600C Review
Discussion in 'Article Discussion' started by Combatus, 8 Dec 2015.
  1. Combatus
    16 Feb 2009
  2. thom804
    thom804 Minimodder
    22 Oct 2009
    All this experimentation with different case orientations.
    I don't know why more manufacturers don't use Silverstone's 90 degree orientation so the hot air is all expelled out of the top of the case. It's the most obvious use of thermodynamics, to have the hot air follow the path it wants to follow.
    Having said all that, i'm pretty sure Silverstone have gone away from that orientation as well, shame.
  3. Vault-Tec
    30 Aug 2015
    Why are the "click on" pics so small? I'm running 4k here the squint fest is unbelievable.
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Same here, the pics are small even with my lowly 1080p res. I also think that cases with "hot swap" bays that don't have a backplane are just half a job.
  5. Combatus
    16 Feb 2009
    Sorry chaps - looks like it was just the final page and a couple on the second that were pointing at the smaller images. Should all be fixed now!
  6. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I actually like it. But a bad little case. So happy they hiding the psu
    Sent from my HTC One M9 using Tapatalk
  7. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Would be interesting to see the performance when reversing the airflow, having the rear and bottom as intakes and the front as exhaust.
  8. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    what is the clearance of the bottom rad point- will it fit a 60MM rad plus fans? will it also fit with same rad in front location as well?
  9. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
Tags: Add Tags
