Hardware Corsair Crystal Series 570X RGB Review
Discussion in 'Article Discussion' started by Dogbert666, 21 Nov 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You mean something like this?
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I'm gonna go ahead and make the assumption that the article is referencing USB3.1 Gen 2, rather than Gen 1 (the connection used in your link) as I don't think any board currently has a front panel header that supports Gen 2.
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Ah.
  5. Hustler
    Hustler Minimodder
    8 Aug 2005
    Good luck trying to keep this thing smudge & dust free.
    ..cleaning it will drive you bonkers, I guarantee it.
  6. TheMadDutchDude
    23 Aug 2013
    There are motherboards with internal USB 3.1 ports. The MSI X99 Titanium has one, for example. ;)
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    List of USB 3.1 ports on the X99 Titanium:
    USB 3.1 ports(Front)
    1(Gen1, Type C), 4(Gen1, Type A)
    USB 3.1 ports (Rear)
    1(Gen2, Type A),1 (Gen2, Type C), 6(Gen1, Type A)
    Unfortunately "only" Gen1 and despite that it is still among the best boards when it comes to USB 3.1...
    Intel needs a kick in the teeth so they make sufficient bandwidth available for mainboards to go 3.1 Gen2 exclusive.
  8. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Anybody know if you can replace the HD fans for the LL ones and still use the hub.
Tags: Add Tags
