Corsair Dominator Twin2X2048-8888C4DF
Discussion in 'Article Discussion' started by Tim S, 11 Sep 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    I assume the heatsink design is patented? Otherwise it would be nice to see this filter down to other brands. Yes it's fast, but £400+ for memory is silly money...
  3. Tim S
    Tim S OG
    8 Nov 2001
    Corsair has filed patents 'on multiple aspects of this technology', so I would assume so. ;)
  4. DougEdey
    5 Jul 2005
    Mommy, I'm scared.
    But they could be used as a hair comb.
    On a more serious note, shame about the H__U_G_E price tag (compo prize:p) and I wouldn't mind that fan cap personally.
  5. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Wow, that price is ridiculous. :eeek:
    As far as I can see, the price premium over say a £150 set just isn't worth it for most people, as there is hardly any performance difference. :baby:
  6. rupbert
    28 Jul 2002
    Anymore details/thoughts on the fans would be nice, possibly using magnets to keep it so quiet?
  7. Djpuk
    Djpuk What's a Dremel?
    1 Sep 2006
    It seems the real world performance to price ratio makes this an enthusiasts purchase, unless I win the lottery I don't think I will be getting some for my next rig!
    Amazing timings none the less.
  8. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Great idea, it would prop. do the job well as an ueber geek comb.
  9. atanum141
    22 Jul 2004
    I can hear Highlander reaching for his wallet as we speak........
  10. Guest-16
    Guest-16 Guest
    I dont know why they didnt use an axial fan to remove dead spots from having three 40mms in a row.
  11. rupbert
    28 Jul 2002
    Never seen one, link?
  12. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Is it just me or should the game tests graphs say "fps (higher is better)" rather than "second (lower is better)"?
  13. DougEdey
    5 Jul 2005
    Those fans are Axial, Axial fans blow air across their axis, which is what these fans do...
    I think you mean crossflow fans?
  14. rupbert
    28 Jul 2002
    Yeah that's what confused me.
  15. Tim S
    Tim S OG
    8 Nov 2001
    whoops, yes... my bad. :blush:
    updated :worried:
  16. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    axial:
    crossflow:
    the bottom one i think would be better for this aplication, but it makes more noise.
  17. Tim S
    Tim S OG
    8 Nov 2001
    Surely the top is a radial fan and the bottom is an axial fan?
  18. DougEdey
    5 Jul 2005
  19. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Why..? Have a kit here that cost 1/2 the amount and can get damn close to those timings with the same voltage... ;)
    Look like decent modules, think the speader is overkill... DIMM's here don't get hugely hot with 2.45v running through them thats with a normal spreader and only a slight breeze from a fan over the graphics card.
    <edit> although the lack of case might contribute somewhat, a little airflow from the heatsink should make the extra fannage un-necessary though) </edit>
    BTW guys, you have a set of 6400 C3 right? Bung 2.4 (or more) volts through that and you should be able to run 3,3,3,x timings way into the 400's quite happily. Might even get to x,2,2,x at 400mhz :)
  20. rupbert
    28 Jul 2002
    I don't know what memory you are using, but most enthusiast ram even slightly overclocked feels very hot to the touch...
Tags: Add Tags
