Case Mod - In Progress Corsair Graphite 490T bullet - update: 150811 - Final Pics before Gamescom
Discussion in 'Project Logs' started by thechoozen, 1 Mar 2011.
  1. thechoozen
    thechoozen Minimodder
    9 May 2006
    thx m8!!
    and here comes the 2nd update for today :D
    Yesterday, we already prepared the next cuts on the sidepanel...thats were we started today...after cutting out the window...we continued with a few cuts around the window...so that we can bend the complete part a bit inside the case...that way we get a nice air intake....
    Beside that we also started the work on the reservoir for the watercooling system....for that we cut out a big top & bottom plate and we also cutted the body of the reservoir which we then bended...first we were not sure how big we will make the reservoir...so we made the top/bottom a bit bigger so that we can change the size later....
  2. KidMod-Southpaw
    28 Sep 2010
    Looking very good- I can't wait to see the plastic on the case!
  3. MilOk
    MilOk What's a Dremel?
    18 Dec 2010
    great job man. i love it :p
  4. Rodrigo Vicentini
    Rodrigo Vicentini What's a Dremel?
    30 Apr 2006
    Oo wow
    nice =D
  5. Rodrigo Vicentini
    30 Apr 2006
    Oo wow
    nice =D looking so good :thumb:
  6. thechoozen
    9 May 2006
    thx a lot !! :rock:
    Yesterday a nice little packet arrived....therefor we want to send a big Thank You!!! :thumb: to Gigabyte for their Support!!!:rock:
    beside that we already started to assemble the sidepanel. For that we first spot welded the outer panel so that we could add another sheet of metal to the inside of the panel which brings more stability to the cuts we want to close...
    After that we added the next metal pieces which we had to cut & bend first, they cover the gap between the bended part and the rest of the sidepanel. They´re already attached to the sidepanel and a first layer of bondo is on the panel...so that we can continue tomorrow...
  7. KidMod-Southpaw
    28 Sep 2010
    Looks like some good fabrication. Well done!
  8. mpe91
    mpe91 Wait... Wha...?
    8 Dec 2010
    That is some awesome work. It almost looks like the case was always meant to be that size. ;)
  9. H4B4N0S
    H4B4N0S What's a Dremel?
    5 Mar 2011
    Good work but I don't agree with your left panel. I'm waiting for next part of your rebuild and, or rather the finish part whose is paint part (in my opinion the hardest) :thumb:
  10. thechoozen
    9 May 2006
    thx m8´s!!
    yeah thats true....it´s really one of the hardest parts :D
    But i´m sure it will look pretty nice when it´s done :D the laquer is already ordered and should arrive in the next days :rock: (black/orange color combination)
    Today we nearly finished the work on the first sidepanel, and also started to assemble the 2nd panel. Beside that we also started to make a small detail for the inside ....a few plexi letters which we cut out. We will do the same from metal, glue both parts together and add a led to the plexilayer. Both will be placed upon the Midplate, so that you can see the glowing edges through the window.....
  11. KidMod-Southpaw
    28 Sep 2010
    Yums. Some nice progress here, it's looking great and I can't wait to see it all together!
  12. thechoozen
    9 May 2006
    thx, and with a bit of luck, it should not take so long :D
    in last days we were spending the most of our time in sanding the sidepanels so that we will get a perfect surface before we start the painting process....
    Beside that we also made a first LED Element which will be placed on the backside of the inner case.
    k.3nny likes this.
  13. KidMod-Southpaw
    28 Sep 2010
    Very nice finish on that, looks like it's made by Corsair. This could be a product suggestion?
  14. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    This is amazing! Cannot wait to see this finished!
  15. H4B4N0S
    5 Mar 2011
    Nice, when I think I had believed I would disagree with your paint, really nice (I apologize for answering in bad english);):jawdrop:
  16. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    mini 600T Cheesecake!
    Looking awesome, Go on pleaaase :D!
  17. morkfromork
    morkfromork Minimodder
    2 May 2010
    Looking very good. The finish on that panel is fantastic.
  18. thechoozen
    9 May 2006
    thanks a lot m8´s :thumb:,
    but that is "only" the base :D today our laquer arrived :D now the eye candy can begin :rock:
    before the package arrives we finished the preparations for the next coats...so it was just perfect timing.
    Beside that we also spent a bit of time on the reservoir. First we had to cut out a few small plexi parts which we glued onto a small piece of a Plexiglas tube. After that we drilled a hole into the reservoir so that we can attach a small rod to it on which the propeller could spin inside the reservoir.
    The LED´s were also soldered....
    Waynio likes this.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    This is the choozen bro's I'm a big fan of :D:rock::clap:, awesome job on the minimising of the case & the res is really really cool +rep, certainly don't need to tell you guys to mod on :D:thumb:.
    PS sorry about poking my nose in on that dispute a bit ago guys, I just felt it was going somewhere not so good, I should have stayed the heck out of it like most other serious stuff, serious topics aren't my thing so I should steer clear :lol: :duh:.
  20. KidMod-Southpaw
    28 Sep 2010
    WOW! Nice res, I want to buy the case.
