Hardware Corsair Graphite Series 380T Review
Discussion in 'Article Discussion' started by Combatus, 29 Aug 2014.
  1. Combatus
    16 Feb 2009
  2. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Its a shame about the temperature results, looking at it, it could be a prodigy beater. I'm kind of relieved it runs warmer though otherwise I'd be tempted to go get one !
    I know the looks won't be to everyone's tastes but I like it, apart from the colour. It's nice to see companies doing something other than rectangular boxes.
  3. David
    7 Apr 2009
    £110 and you too can make your PC look like a space heater.
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    So far we've had kitty carrier, paper shredder and now space heater. Keep 'em coming folks.
  5. rollo
    rollo Modder
    16 May 2008
    It's been tested differently elsewhere and there results using real coolers look a lot more favourable than your low profile one. Think this case would be best under water anyway for the CPU. Can't say I'd be a buyer though the whole micro atx craze is not for me.
  6. Woodspoon
    Woodspoon What's a Dremel?
    10 May 2008
    I think it's a nice looking case tbh, makes a change from the beige now black boxes we've been constantly getting.
  7. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    If Corsair offered it in other colours it'd be an absolute winner. Green and blue as two others would make its appeal greater. I for one love it and already looking to swap to mini-ITX. Also, looks like a cool box at a glance...
    Question, does it support PSU over 160mm, not sure reading the review here...
  8. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Also comes in all black:
    And black and white:
  9. Dogbert666
    17 Jan 2010
    Maybe re-read it then :p
    By default, no. And as was pointed out this is mentioned in the review. As is the fact that if you remove the front HDD cage, you can install a longer PSU as there will be nothing blocking the extra length
  10. mikemaher205
    14 Aug 2011
    I read this late at night and was tiered...
    So its got no coffee holder either? What will I do with my cup now?
    I'll get my coat.
  11. Anfield
    Anfield Multimodder
    15 Jan 2010
    Although its kind of silly how small the selection of decent small psus is, development in that area is severely lagging behind the trend towards smaller mainboards and cases.
  12. MightyBenihana
    MightyBenihana Colour my life with the chaos of trouble
    8 Sep 2011
    Would there be space to fit a dual 120mm rad in at the front with the HDD cage removed? (Thereby allowing 2x dual 120mm rads to be fitted in total?)
  13. David
    7 Apr 2009
    A mate of mine clearly fancies the space heater look but was turned off after reading this review - he says it'll be far too big. I thought he was tripping, until I noticed the dimensions listed on page one - It should have been obvious, but he takes everything at face value. :rolleyes:
    They should read 393mm x 292mm x 356mm (LWH) ;)
  14. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Yeah, I did a bit of a double-take when I saw the dimensions listed in the review, realised that they must be a load of pony and looked up the correct dimensions elsewhere :D
Tags: Add Tags
