Cooling Corsair h-80 + h-100
Discussion in 'Hardware' started by donok, 31 May 2011.
  1. donok
    donok Every Little Helps .....
    16 Feb 2011
    H-80 and h-100 out to preorder at scan.
  2. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    5 Year warranty + 2011 support @ good price = Nice!
    May upgrade to one of these (probs the H100) when I upgrade this autumn to 2011+GTX 6 series
  3. donok
    16 Feb 2011
    I would put the link up but on my cellphone (American accent) lol
  4. Guest-23315
    Guest-23315 Guest
  5. donok
    16 Feb 2011
    Thanks dude. They look pretty sweet. And more towards enthusiasts as they have controls on em
  6. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    I would have thought enthusiasts would have just gone straight for a real loop rather than a single CPU cooler like the corsair H series?
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
  8. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    I shall await reviews, unless the performance is really notable ie temp drops of 8-10c or more then a upgrade from either the current range of sealed coolers is unlikely worth it..
  9. Bloody_Pete
    11 Aug 2008
    The H100 will be the one to watch really...
  10. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    I'd be all over that H-100. It would sit nicely in the roof of a case. Mmmyes.
  11. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I have a H50 in both my machine the minute the h100 arrives I am going to get out and try it out
    Sent from my GT-I9000 using Tapatalk
  12. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    +1
    i'll an eye on it, would fit nicely on "roof" of my ATCS 840 :naughty:
  13. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Would love to see what performance you get from the H100. 240 rad Cheesecake!
  14. donok
    16 Feb 2011
    cant wait for reviews
    that h-80 is similar price to the h70
  15. Bloody_Pete
    11 Aug 2008
    Its basically the same, just with some controller gizmos built in...
  16. Droih
    Droih Your too close if you can read this
    17 May 2010
    That controller gizmo seems awsome tho, controlling case fans with your CPU Cooler O_O
    If you are considering h80 or h100 check these cases out, built for the compact cooling of h6/7/8/100 :D
    Corsair Carbide 400R and 500R
  17. Instagib
    Instagib Minimodder
    12 Mar 2010
    I'm surprised Corsair haven't done the H-100 sooner; ALC did a CoolIt-240 ages ago.
  18. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i wonder when will corsair make one bof these for graphics cards ?
    it could be awesome :D
  19. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    they did (well, coolit did before they partnered with corsair).
    problem is, its hard to make a universal mounting system for a broad range of GPUs. these coolers are too expensive to replace every time you upgrade your graphics card.
  20. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    hmm definitely preordering the h100, dont suppose anyone needs an h70 :p
