Cooling Corsair H100
Discussion in 'Hardware' started by Kovoet, 14 Jul 2011.
  1. Salisant
    Salisant What's a Dremel?
    17 Jul 2011
    Am interested to see how this performs, Corsair needs to hurry up and get review samples out to reviewers...
  2. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    I'm reviving this thread because I just read a nice in-depth review about this cooler and I thought some of the people who posted here might be interested :):
    article here
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    mmm I like the look of this thank you
  4. trig
    trig god's little mistake
    10 Aug 2006
    i guess for what you get, it's probably worth it, and those oc results were more impressive...and let's be honest, if you're not overclocking, you shouldn't be buying this kit, so based on that, i guess it would be worth the premium, but again, the h70 looks perfectly acceptable...
  5. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Although it does look tempting, and I already have an abundance of gentle typhoons in the case to set it up as push/pull... I don't think I can justify the £ to bring temps down a couple of degrees.
    In my current setup, it's the case that's holding my temps back, but I love the 800D too much to get rid of it. Guess I might have to bite the bullet and go full water cooling then.
  6. trig
    10 Aug 2006
    well, at least that case was built with water cooling in mind...plenty of room in there supposedly...
  7. Sentinel-R1
    13 Oct 2010
    There is indeed. I've had Richey Edwards from the Manic Street Preachers hidden out in here for years now....
  8. trig
    10 Aug 2006
    lol
  9. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    The only thing that makes the H100 worth buying is to make it run with low rpm fans and have the same cooling performance to a H50/60. I have a spare H70 but it can't fit in my case so... :(
    Currently I'm using the H50 with a single gentle typhoon running a mildly overclocked core i7 920.
    I mean cpu cooling is already doing well and the only thing that needs to be figured out would be sealed GPU cooler. Last time I've heard it was the CoolIT OMNI ALC. For me getting all the custom water cooling parts at a good price is harder since there is only one local reseller and the rest would have to be imported from overseas. And since I have no one around me who has dabbled with a watercooling loop its hard to get help.
