Hardware Corsair H100i review
Discussion in 'Article Discussion' started by brumgrunt, 5 Dec 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    What are my chances of this fitting in the top of my R4?
  3. GeorgeK
    18 Sep 2010
  4. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Thanks guys. Well with my coolermaster haf x it fits easy and above I will have 2x200mm fans which I'm tempted to leave on.
    Can't wait for mine to arrive now.
  5. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    I bodged mine (original H100 with an R3, not R4) in because the Sabertooth Z77 has a huge shroud on it which meant it was impossible to get it to line up with the back screw holes. As mentioned above, it depends heavily on your mobo.
    I've been running mine for 6 months, ''bolted'' in with 4 cable ties, it works beautifully, still. :thumb:
    PS: This was a pic during the build, so yes, it's untidy. I was going to be replacing the PSU a week after. .
    YEHBABY likes this.
  6. Pookie
    4 May 2010
    I have a GA-X58A-UD3R, I will crack my case open on the weekend and do some measuring up as I really want one of these. I can alway opt for the H80i which is not far off the H100i :)
  7. GeorgeK
    18 Sep 2010
    I plan to put mine in my current case (CM690II Advanced) - I'm going to put the radiator in the roof cavity and the fans inside the case acting as exhausts - for me I won't fit the radiator and the fans inside the case...
  8. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    will fit in my HAF922, but, much as I'd like it, I probably don't need it...
  9. brutos
    brutos What's a Dremel?
    24 Feb 2011
    I must upgrade my H8o0 to this for my 3820
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    I was amazed at this thing's cooling. Genuinely thought our 1155 rig capped out at a 36°C delta T before this week; Nope!
  11. dazzler
    dazzler What's a Dremel?
    24 Nov 2012
    Was tempted by this but it'll involve a bit of work to fit it in the Zalman Z11 case I just got, not decided yet whether to go with the Silver Arrow Extreme or try a bit of modding!
  12. rollo
    rollo Modder
    16 May 2008
    Might be time for Bit tech to invest in a bigger case for CPU Coolers like this one as i wonder how it would perform inside a case compared to outside were its getting fresh air constantly.
  13. David
    7 Apr 2009
    How did you kill the AMD rig, Harry? Anything spectacular?
  14. GeorgeK
    18 Sep 2010
    I imagine he plugged in 'the' hard drive...
    David likes this.
  15. DoctorBeat
    DoctorBeat What's a Dremel?
    27 Jul 2006
    I've cut holes on the roof of my Fractal XL to accommodate the H100 6 months ago...
    with a i7 3870 overclocked to 4.6Ghz it works flawlessly. In the meantime I've swapped the fans for a noctua NF-F12 and the thing is whisper quiet
    I can only thing of good things to say about my H100, hopefully this one is better
Tags: Add Tags
