Hardware Corsair HS1A Review
Discussion in 'Article Discussion' started by arcticstoat, 20 Apr 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
    Claave likes this.
  2. lerxster
    lerxster What's a Dremel?
    9 Sep 2009
    Patiently waiting for some 5.1 analog ones. The USB ones have the random reverse stereo bug. Also makes my Asus soundcard redundant!
  3. Jipa
    5 Feb 2004
    I reviewed the HS1A recently as well and am really loving the headset. The build quality is superb for the price and the sound quality (par the slightly lacking bass response) is really nice as well.
    Recommended.
  4. Tangster
    23 May 2009
    £17 price cut? The HS1 must've been pretty overpriced.
  5. Phifty Cal
    Phifty Cal What's a Dremel?
    28 Mar 2010
    Take a look at Turtle Beach HPA-2s if you want 5.1 analogue. I use them and they sound pretty damn nice :)
  6. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    the price difference on newegg is only $10, making the analog set still $90....seems a little (lot) steep to me.
  7. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    You would honestly be much better getting a stereo headset with some nice phat drivers and using positional audio emulation, assuming you have a soundcard. It works just as well, and you get the benefits for general sound reproduction of having single, high quality drivers, rather than several lesser ones.
    Of course, if you don't have a soundcard, you are kind of out of luck. But getting even these headphones without a soundcard seems a little wasteful.
  8. alialias
    alialias What's a Dremel?
    1 Dec 2010
    Is the microphone detachable? It doesn't look like it is, but i've always been intrigued what a headset such as this would be like for listening to music on the bus with...
  9. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    No, not detachable - if you used these on the bus you'd look like a prize fool. Annoying really.
Tags: Add Tags
