Electronics Corsair hx750w black connector pin outs (Problem Solved)
Discussion in 'Modding' started by DampSquid, 4 Jan 2012.
  1. DampSquid
    DampSquid What's a Dremel?
    29 Aug 2011
    Need a bit of help on my first mod.
    I'm looking to tidy up some of the mountain of cables inside my case by connecting all the fans to a custom fan controller and connecting that to the PSU. Problem is that I don't have the psu to molex cable I was planning to use.
    Does anyone know where I can find a diagram of the output voltages of the pins on the black connectors on the psu. tried corsair website but got nothing.
    Or if anyone has the psu to molex cable could you describe which pins on the psu end go to which pins on the molex end.
    Thanks in advance to any responses.
    EDIT:
    Solved the problem, used a SATA power cable pin out diagram to track it back.
