Hardware Corsair Hydro H105 Review
Discussion in 'Article Discussion' started by Meanmotion, 7 Feb 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Panos
    Panos Minimodder
    18 Oct 2006
    Nice review.
    Corsair makes some pretty descent closed loop solutions tbh. Both my H50 over the last 3 years and the H100i are absolutely superb. However their fans are very loud on 100%
    Hence I have replaced the fans with 4 Akasa Apache working at max speed on the H100i and havent looked back. Is quiet, and cools my 4820K @ 5Ghz pretty fine.
  3. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
  4. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Sounds good, any chance of testing a hot AMD CPU with it ?
  5. Shirty
    18 Apr 1982
    Who's abusing the diforumadmin login to spam the comments section???
    :p
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    It seems to be getting more complicated to understand model placements in their hierarchy, with the standard (H100), 'i' and now '5' versions.
    Can't deny though that whatever AIO you buy from Corsair, you are getting a great product.
  7. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Very nice :) nice to see them refresh it every so often :)
  8. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    When's the H107&1/2 gonna hit the shops i wonder....
  9. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Any way to tell if it's a CoolIt or Asetek unit?
  10. Shirty
    18 Apr 1982
    Asetek.
  11. SchizoFrog
    5 May 2009
    Bit-Tech, can I ask if there is a particular reason you fit the radiator that way round or can you rotate it 180'? I ask as that great loop in the cable doesn't look the tidiest.
    Also, something else comes to mind with all AIO's is that a full custom water loop contains a reservoir for a reason. What is the liquid durability in these AIO's? Can the liquid be replaced/topped up if needed without voiding warranty? If not, what is the life expectancy of an AIO due to it's liquid limitations (ie: evaporation, clogging, etc)?
Tags: Add Tags
